[AG-TECH] Remote Device Control trouble
    Eric Olson
    eolson at mcs.anl.gov
    Tue Dec 20 14:01:33 CST 2005
Hi Paul,
On the mac, you have to initialize the AG environment in your terminal
before running a command-line application like agpm.  If you run the
following line first, it should work.
Also, this assumes you're using the bash shell, which is the default.
  . /Applications/AccessGridToolkit.app/Contents/Resources/setupenv.sh
Eric
Paul Mercer wrote:
> All
> I'm trying to install and test the Remote Device Control on my mac
> running tiger.  Following the instructions at
> http://trac.agcentral.org/AGDeviceControl/wiki/UnixInstallHowTo
> I installed checked the python packages agdevicecontrol ok
> but when I try to register the Node Service
> I get this error:
> [polaris-e0:/Users/Shared/agdevicecontrol-0.5.4] support% sudo
> /Applications/AccessGridToolkit.app/Contents/Resources/bin/agpm.py
> --package=DeviceControlService.zip
> Password:
> Traceback (most recent call last):
>   File
> "/Applications/AccessGridToolkit.app/Contents/Resources/bin/agpm.py",
> line 25, in ?
>     from AccessGrid.AppDb import AppDb
> ImportError: No module named AccessGrid.AppDb
> I opened python and typed help() and then modules and agdevicecontrol is
> there but no AccessGrid or AppDb.
> Where can I get these modules?  The AG runs fine on my mac.
> Can someone please help?
> thanks in advance
> Paul
