[AG-TECH] Mac OS X PackageMaker and AccessGrid problems
Eric Olson
eolson at mcs.anl.gov
Wed Dec 14 10:46:51 CST 2005
Hi Ashnil,
Can you tell us why it needs to be repackaged for OSX Server? Is there
a reason why installing the package for OSX Tiger or Panther would not work?
Eric
Ashnil Kumar wrote:
> I was recently pointed to
> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/*checkout*/AccessGrid/
> doc/AG-Mac-Build-HOWTO.rtf?rev=1.2.2.4&only_with_tag=r_2_3_final to
> build the AccessGrid for Mac OS X.
> I have followed the instructions there, using the older versions of
> fpconst and SOAPpy as required. I still run across a major problem when
> running BuildSnapshot.py (the main build python script). Once
> BuildPackage.py is called and executes PackageMaker the build seems to
> take a very very long time to make the package. It is still taking up
> CPU cycles according to 'top'. I let the packaging continue over a day
> or two and it was still going.
> The output at this point is given below, as well as some errors that
> occurred before the packaging.
> cmd = /usr/bin/python BuildPackage.py --verbose -s
> /Volumes/Data/mnt/agscratch -b /Volumes/Data/mnt/agscratch/AccessGrid
> -d /Volumes/Data/mnt/agscratch/dist-20051214_102445 -p 2.3 -m
> Snapshot_20051214_102445 -v 3.0
> SourceDir = /Volumes/Data/mnt/agscratch
> BuildDir = /Volumes/Data/mnt/agscratch/AccessGrid
> DestDir = /Volumes/Data/mnt/agscratch/dist-20051214_102445
> metainfo = Snapshot_20051214_102445
> version = 3.0
> TmpDir: /tmp/tmpmhTRvA
> Backing up old file: ../AGTk-3.0 to ../AGTk-3.0.old
> Removing old backup (directory): ../AGTk-3.0.old
> Running packaging command:
> /Developer/Applications/Utilities/PackageMaker.app/Contents/MacOS/
> PackageMaker -build -p ../AGTk-3.0/AGTk-3.0.pkg -f
> /tmp/tmpmhTRvA/pkg_contents -ds -r /tmp/tmpmhTRvA/pkg_resources -i
> /tmp/tmpmhTRvA/pkg_contents/AccessGridToolkit.app/Contents/Info.plist
> -d /tmp/tmpmhTRvA/pkg_resources/Description.plist
> Before this, there were a few errors that did not stop the build process:
> Calling build script: VideoService.build.py
> ** Error: Unsupported platform: darwin
> Traceback (most recent call last):
> File "VideoService.build.py", line 25, in ?
> VIC_EXE_PATH = os.path.join(servicesDir,VIC_EXE)
> NameError: name 'VIC_EXE' is not defined
> Writing Package File:
> /mnt/agbuild/dist-20051209_103015/NodeServices/VideoService.zip
> Calling build script: AudioService.build.py
> File "AudioService.build.py", line 34, in ?
> for f in ratFiles:
> NameError: name 'ratFiles' is not defined
> /mnt/agbuild/dist-20051209_103015/NodeServices/AudioService.zip
> Calling build script: VideoProducerService.build.py
> File "VideoProducerService.build.py", line 25, in ?
> /mnt/agbuild/dist-20051209_103015/NodeServices/VideoProducerService.zip
> Calling build script: VideoConsumerService.build.py
> File "VideoConsumerService.build.py", line 24, in ?
> Examining the files in question, there is no sys.platform == 'darwin'
> option.
> Any help as to how to get the AccessGrid built and packaged for Mac OS
> X Server 10.3 would be much appreciated.
> Thanks,
> Ashnil
