[AG-TECH] Mac OS X PackageMaker and AccessGrid problems
Ashnil Kumar
akum5948 at mail.usyd.edu.au
Tue Dec 13 18:50:44 CST 2005
I was recently pointed to
http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/*checkout*/AccessGrid/
doc/AG-Mac-Build-HOWTO.rtf?rev=1.2.2.4&only_with_tag=r_2_3_final to
build the AccessGrid for Mac OS X.
I have followed the instructions there, using the older versions of
fpconst and SOAPpy as required. I still run across a major problem when
running BuildSnapshot.py (the main build python script). Once
BuildPackage.py is called and executes PackageMaker the build seems to
take a very very long time to make the package. It is still taking up
CPU cycles according to 'top'. I let the packaging continue over a day
or two and it was still going.
The output at this point is given below, as well as some errors that
occurred before the packaging.
cmd = /usr/bin/python BuildPackage.py --verbose -s
/Volumes/Data/mnt/agscratch -b /Volumes/Data/mnt/agscratch/AccessGrid
-d /Volumes/Data/mnt/agscratch/dist-20051214_102445 -p 2.3 -m
Snapshot_20051214_102445 -v 3.0
SourceDir = /Volumes/Data/mnt/agscratch
BuildDir = /Volumes/Data/mnt/agscratch/AccessGrid
DestDir = /Volumes/Data/mnt/agscratch/dist-20051214_102445
metainfo = Snapshot_20051214_102445
version = 3.0
TmpDir: /tmp/tmpmhTRvA
Backing up old file: ../AGTk-3.0 to ../AGTk-3.0.old
Removing old backup (directory): ../AGTk-3.0.old
Running packaging command:
/Developer/Applications/Utilities/PackageMaker.app/Contents/MacOS/
PackageMaker -build -p ../AGTk-3.0/AGTk-3.0.pkg -f
/tmp/tmpmhTRvA/pkg_contents -ds -r /tmp/tmpmhTRvA/pkg_resources -i
/tmp/tmpmhTRvA/pkg_contents/AccessGridToolkit.app/Contents/Info.plist
-d /tmp/tmpmhTRvA/pkg_resources/Description.plist
Before this, there were a few errors that did not stop the build
process:
Calling build script: VideoService.build.py
** Error: Unsupported platform: darwin
Traceback (most recent call last):
File "VideoService.build.py", line 25, in ?
VIC_EXE_PATH = os.path.join(servicesDir,VIC_EXE)
NameError: name 'VIC_EXE' is not defined
Writing Package File:
/mnt/agbuild/dist-20051209_103015/NodeServices/VideoService.zip
Calling build script: AudioService.build.py
File "AudioService.build.py", line 34, in ?
for f in ratFiles:
NameError: name 'ratFiles' is not defined
/mnt/agbuild/dist-20051209_103015/NodeServices/AudioService.zip
Calling build script: VideoProducerService.build.py
File "VideoProducerService.build.py", line 25, in ?
/mnt/agbuild/dist-20051209_103015/NodeServices/VideoProducerService.zip
Calling build script: VideoConsumerService.build.py
File "VideoConsumerService.build.py", line 24, in ?
Examining the files in question, there is no sys.platform == 'darwin'
option.
Any help as to how to get the AccessGrid built and packaged for Mac OS
X Server 10.3 would be much appreciated.
Ashnil
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20051214/4033c387/attachment.bin>
