[AG-TECH] GLOBUS_HOSTNAME problems
Thomas D. Uram
turam at mcs.anl.gov
Sat Aug 27 18:21:21 CDT 2005
The problem with the anonymous certificate was identified and fixed in
the 2.4 release. It would occur with old (pre-2.3) certificate
repositories into which the anonymous CA certificate had been imported
(automatically by the 2.3 software). The CA cert was not properly
tagged, so was not used as a CA cert, causing anon cert verification ops
to fail. Thanks to Darin Oman for submitting his log files; they helped
me understand and resolve the problem.
There is no relationship between the certificate and the hostname.
If you look in the VenueClient.log file (in ~/.AccessGrid/Logs), you
should see an indication of the problem. I'm interested to see the
logfile myself, to see what has gone wrong and try to help.
Tom
Eric Peterson wrote:
> Hi All,
> I am having the same type of problem using 2.4 and Mac OS X 10.4. If I
> use the default anonymous certificate I have no problems running the
> "Manage my Node" and adding and deleting services. However when I
> import my certificate and try to use it, everything breaks. I am not
> able to set URL node etc. Not sure what the certificate has to do with
> being able to set the URL node and hostname but it some how does. I'll
> just be using the anonymous cert for now. Would requesting a new
> certificate fix this?
> Thanks,
> Eric Peterson
> Arctic Region Supercomputing Center
> On 8/24/05, Julia Mullen <julia.mullen at gmail.com> wrote:
>>Hi Tom,
>>I have to support Darin's experience here as we had exactly the same thing
>>happen with Ray Chen at U Maryland that day. You may recall an exchange of
>>email - we had the added complexity of removing the previous expired
>>cert - but once that was removed the anonymous cert still gave us the
>>globus-host error.
>>Once Ray was able to use his own cert the error went away and we were able to
>>connect and test.
>>Ray, can you grab the logfiles from the machine you used and send them to
>>Tom?
>>Thanks,
>> Julie
>>On 8/24/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
>>>Darin:
>>>I'd be very interested to see logfiles from your machines to understand
>>>what went wrong.
>>>There is no relationship whatsoever between the certificate and the
>>>hostname, so switching from an anonymous certificate to an identity
>>>certificate can not have been the solution to the problem.
>>>If you can send the VenueClient.log from the display machine, and the
>>>ServiceManager.log from any remote machine(s) involved, we should be
>>>able to identify the problem.
>>>Thanks in advance for your help, Darin.
>>>Tom
>>>Darin Oman wrote:
>>>>Mike, you RULE! I replaced the anonymous certificate with a good,
>>>>approved cert and it's back to normal! Is this a bug or something done
>>>>on purpose? Either way, people should know about this with DHCP nodes.
>>>>Thanks again! And Julie, thanks for verifying the fix.
>>>>Darin
>>>>On Aug 16, 2005, at 11:52 AM, Michael Miller wrote:
>>>>>I've had the same trouble when trying to use an anonymous cert. not
>>>>>sure how to fix tho'. What does nslookup give for your IP, and
>>>>>conversely for your domain name? They should match up of course, but
>>>>>I've seen the name resolve to a different IP before...
>>>>>MYK
>>>>>Darin Oman wrote:
>>>>>>When I try to "manage my node," I'm told I need to specify the node
>>>>>>service URL, then I'm told that the machine "can not open node
>>>>>>management at https://..." I know this is a problem with DHCP
>>>>>>machines. I've tried set GLOBUS_HOSTNAME and I've also tried to
>>>>>>remove the environment variable. The problem there is that there is
>>>>>>no reference anywhere to GLOBUS_HOSTNAME. No environment variable,
>>>>>>nothing. I've tried removing and reinstalling the Globus parts as
>>>>>>well as the toolkit a number of times. I've also dug through the
>>>>>>registry. The result is always the same. Does anybody have any idea
>>>>>>what I'm missing?
>>>>>>Thanks,
>>>>>>Darin
>>>>>Thanx,
>>>>>Michael Miller
>>>>>System Engineer
>>>>>Video Technology Services
>>>>>Persistent Infrastructure Directorate
>>>>>National Center for Supercomputing Applications
>>>>>University of Illinois - UC
>>>>>217-649-0747
>>>>>"If you're clear in your vision and trust the people in your team with
>>>>>clear objectives, they will invariably do their best to achieve
>>>>>everything desired, and usually deliver everything you could have
>>>>>hoped for and even more." -Paul Debevec
