[AG-TECH] Re: your mail
Gavin W. Burris aka 86
ga5in at psu.edu
Mon Aug 8 13:49:31 CDT 2005
I seem to have fixed our glitch. I believe the problem started when we
installed a quickcam, which installs an additional audio device for the
quickcam's built-in mic.
I fixed it by downloading the latest audio driver for this laptop's
on-board audio device, removing the on-board audio device in Device
Manager, rebooting and re-installing it.
Then I made sure the on-board sound device was the default for recording
from the Sound Control Panel.
Toggling talk in rat now allows listen without talk on.
Cheers.
Gavin W. Burris aka 86 wrote:
> I just had the same problem here! We tried all the sound, mixer, and
> rat options to no end. The funny thing is that this system was fine a
> week ago.
> I tried blowing away the Access Grid settings under Application Data, no
> go. Does anyone know where RAT stores its settings in the registry?
> Locatis, Craig (NIH/NLM/LHC) wrote:
>> We've experienced the same problem here at NLM on our XP
>> machine..............
>> -----Original Message-----
>> From: John Hodrien [mailto:johnh at comp.leeds.ac.uk] Sent: Monday,
>> August 08, 2005 7:27 AM
>> To: ag-tech at mcs.anl.gov
>> Subject: [AG-TECH] Re: your mail
>> On Mon, 8 Aug 2005, Peter DeSantis wrote:
>>> Hi,
>>> has anyone come across an issue with the AG 2.3 software where you find
>> that
>>> you can not receive (hear) audio from any other participants unless your
>>> local "talk" option is enabled. Also i would have expected full duplex
>>> audio operation to allow one to speak and receive audio simultaneously,
>> but
>>> it also appears that when you speak locally and start to transmit
>>> audio it
>>> cuts of the incoming audio. Is this normal ?
>> Definitely not normal. Have you got the dodgy software based echo
>> cancellation turned on in rat or something?
>>> Ive come across this on two XP based machines now. It dont appear to
>>> be a
>>> networking issue in that once talk is enable others can be heard
>>> fine. In
>>> both cases the machines had different audio cards, and one is single Pc
>> the
>>> other a 3 pc system.
>> Doesn't happen with any of our 2000 or linux based machines.
>> jh
Senior Systems Programmer
Penn State Visualization Group
http://viz.aset.psu.edu/ga5in
