[AG-TECH] Re:
Derek Piper
dcpiper at indiana.edu
Mon Aug 8 08:57:21 CDT 2005
Yes, I've observed this too (the first phenomenon) on a Dell Optiplex
PC (using its built in sound) running Windows XP. It appears unless a
small noise is made, the audio playback is cut off. RAT still operates
its VU meter and is receiving data, just no sound comes out. I have an
echo-cancelling microphone too, from this kit:
http://www.globalmedia.com/index.php?dest=store&gmenu=5&a=pop%20kits&c=&d=GMK1911&smenu=&i=1
Derek
Peter DeSantis wrote:
> Hi,
> has anyone come across an issue with the AG 2.3 software where you find that you can not receive (hear) audio from any other participants unless your local "talk" option is enabled. Also i would have expected full duplex audio operation to allow one to speak and receive audio simultaneously, but it also appears that when you speak locally and start to transmit audio it cuts of the incoming audio. Is this normal ?
> Ive come across this on two XP based machines now. It dont appear to be a networking issue in that once talk is enable others can be heard fine.
> In both cases the machines had different audio cards, and one is single Pc the other a 3 pc system.
> Thanks
> Peter DeSantis
> peter at jumbovision.com.au
> Jumbo Vision International Pty Ltd
> Unit 2 ,1 Aitken Way
> Kewdale WA 6105
> Australia
> Tel: 61 8 9353 6200
> Fax: 61 8 9353 6211
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
