[AG-TECH] Re: your mail
Fred Dech
fdech at uchicago.edu
Mon Aug 8 08:27:04 CDT 2005
i've also seen this on a linux AG client. however, there are some other
funky things going on with that particular client. so i just don't use
it. ;^)
--fred
On Mon, Aug 08, 2005 at 12:58PM, Mike Daley said:
> Hi
> I have seen this several times on my Desktop Windows setup. But have no
> explanations.
> I have changed sound cards and still seen the same problem. But its not
> very reproducable.
> Mike
> John Hodrien wrote:
> >On Mon, 8 Aug 2005, Peter DeSantis wrote:
> >>Hi,
> >>has anyone come across an issue with the AG 2.3 software where you
> >>find that
> >>you can not receive (hear) audio from any other participants unless your
> >>local "talk" option is enabled. Also i would have expected full duplex
> >>audio operation to allow one to speak and receive audio
> >>simultaneously, but
> >>it also appears that when you speak locally and start to transmit
> >>audio it
> >>cuts of the incoming audio. Is this normal ?
> >Definitely not normal. Have you got the dodgy software based echo
> >cancellation turned on in rat or something?
> >>Ive come across this on two XP based machines now. It dont appear to
> >>be a
> >>networking issue in that once talk is enable others can be heard
> >>fine. In
> >>both cases the machines had different audio cards, and one is single
> >>Pc the
> >>other a 3 pc system.
> >Doesn't happen with any of our 2000 or linux based machines.
> >jh
