[AG-TECH] Re: your mail
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Mon Aug 8 06:58:53 CDT 2005
Hi
I have seen this several times on my Desktop Windows setup. But have no
explanations.
I have changed sound cards and still seen the same problem. But its not
very reproducable.
Mike
John Hodrien wrote:
> On Mon, 8 Aug 2005, Peter DeSantis wrote:
>> Hi,
>> has anyone come across an issue with the AG 2.3 software where you
>> find that
>> you can not receive (hear) audio from any other participants unless your
>> local "talk" option is enabled. Also i would have expected full duplex
>> audio operation to allow one to speak and receive audio
>> simultaneously, but
>> it also appears that when you speak locally and start to transmit
>> audio it
>> cuts of the incoming audio. Is this normal ?
> Definitely not normal. Have you got the dodgy software based echo
> cancellation turned on in rat or something?
>> Ive come across this on two XP based machines now. It dont appear to
>> be a
>> networking issue in that once talk is enable others can be heard
>> fine. In
>> both cases the machines had different audio cards, and one is single
>> Pc the
>> other a 3 pc system.
> Doesn't happen with any of our 2000 or linux based machines.
> jh
