[AG-TECH] Re: your mail
John Hodrien
johnh at comp.leeds.ac.uk
Mon Aug 8 06:26:40 CDT 2005
On Mon, 8 Aug 2005, Peter DeSantis wrote:
> Hi,
> has anyone come across an issue with the AG 2.3 software where you find that
> you can not receive (hear) audio from any other participants unless your
> local "talk" option is enabled. Also i would have expected full duplex
> audio operation to allow one to speak and receive audio simultaneously, but
> it also appears that when you speak locally and start to transmit audio it
> cuts of the incoming audio. Is this normal ?
Definitely not normal. Have you got the dodgy software based echo
cancellation turned on in rat or something?
> Ive come across this on two XP based machines now. It dont appear to be a
> networking issue in that once talk is enable others can be heard fine. In
> both cases the machines had different audio cards, and one is single Pc the
> other a 3 pc system.
Doesn't happen with any of our 2000 or linux based machines.
jh
"Computers are useless. They can only give you answers."
-- Pablo Picasso
