No subject
Peter DeSantis
peter at jumbovision.com.au
Sun Aug 7 22:49:18 CDT 2005
has anyone come across an issue with the AG 2.3 software where you find that you can not receive (hear) audio from any other participants unless your local "talk" option is enabled. Also i would have expected full duplex audio operation to allow one to speak and receive audio simultaneously, but it also appears that when you speak locally and start to transmit audio it cuts of the incoming audio. Is this normal ?
Ive come across this on two XP based machines now. It dont appear to be a networking issue in that once talk is enable others can be heard fine.
In both cases the machines had different audio cards, and one is single Pc the other a 3 pc system.
Thanks
Peter DeSantis
Jumbo Vision International Pty Ltd
Unit 2 ,1 Aitken Way
Kewdale WA 6105
Australia
Tel: 61 8 9353 6200
Fax: 61 8 9353 6211
