[AG-TECH] AG security and multicast ?
Derek Piper
dcpiper at indiana.edu
Fri Apr 15 11:24:00 CDT 2005
Okay, thanks, that sounds promising. I'll take a look at it.
Derek
Ivan R. Judson wrote:
> That's a great idea. Have you looked at the VenueClient.py object? There's not only an API it uses, but it manages some state for
> anyone that want's to use the Venue. Last time I checked one of the things that was supposed to be coming in the next release was a
> standard WSDL interface to the venue and venueserver.
> This might be a good place to start looking at CVS and seeing if there are hints of those parts, and how to use them if they're
> showing up.
> --Ivan
>>-----Original Message-----
>>From: Derek Piper [mailto:dcpiper at indiana.edu]
>>Sent: Wednesday, April 13, 2005 9:48 AM
>>To: judson at mcs.anl.gov
>>Cc: ag-tech at mcs.anl.gov; 'Adam Taylor'
>>Subject: Re: [AG-TECH] AG security and multicast ?
>> Hi,
>> Since the 'brainstorming' appears to have died down a
>>lot.. What about a published API for interacting with the
>>venue server? Then we can all go write our tools/add-ons and
>>be happy. Good ones can be incorporated into the main AG
>>software, i.e. pass codes etc.
>> Derek
>>>The beauty of Adam's suggestion is that it's exactly what
>>the AG team
>>>has been trying to get enough time to build. This is the
>>kind of work
>>>we'd like to see -- but I don't believe the NCSA scheduler has been
>>>released yet for others to hack on it. The work I believe
>>is a small
>>>amount using the existing interfaces that are available.
>>>If this can't be done in short order, I support Brian's
>>point that for
>>>most users a passcode/password -- similar to what is used by
>>>conference calls or web meeting software, should be sufficient _to
>>>gain access_ to the venue (to get past the bouncer), but
>>it's really
>>>of *no* use if the communication within the venue isn't
>>secure -- then
>>>as Jennifer points out, you're only relying on obscurity.
>>>Who wants to hack on the scheduling software (either NCSA's
>>or a new one)?
>>>That's where the interesting "automation" is. It won't
>>solve all the
>>>ad-hoc stuff, but it'd go a long way towards solving a lot of the
>>>mundane problems...
>>>--Ivan
>>>>From: owner-ag-tech at mcs.anl.gov
>>>>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Adam Taylor
>>>>Sent: Monday, April 11, 2005 11:01 AM
>>>>To: ag-tech at mcs.anl.gov
>>>>Subject: RE: [AG-TECH] AG security and multicast ?
>>>>My two cents...
>>>>To bad there wasn't a way that when you go to confirm you
>>reservation
>>>>in the AG Scheduler you must enter the DN of the site you
>>will be at
>>>>to confirm your reservation. Then, 5 min or so before the meeting
>>>>starts, a background process (something that can talk to the venue
>>>>server and scheduler) reads in the DNs from the scheduler for that
>>>>room and time and sets the ACL for that room for that given
>>scheduled
>>>>time block. When that meeting is over, the background
>>process removes
>>>>that ACL for that room and creates another one for the next
>>meeting in
>>>>that room. If there is more then 30 min or so between
>>meetings then
>>>>the background process just removes the ACL for that period
>>of time.
>>>>Just make sure all rooms are encrypted (different key per
>>meeting or
>>>>something like that) and that should make it pretty secure.
>>>>At least in my head it does :-)
>>>>Adam Taylor
>>>>Computing Center
>>>>University of Louisiana at Monroe
>>Derek Piper - dcpiper at indiana.edu - (812) 856 0111 IRI 323,
>>School of Informatics Indiana University, Bloomington, Indiana
IRI 323, School of Informatics
