[AG-TECH] AG security and multicast ?
Ivan R. Judson
judson at mcs.anl.gov
Wed Apr 13 22:12:58 CDT 2005
That's a great idea. Have you looked at the VenueClient.py object? There's not only an API it uses, but it manages some state for
anyone that want's to use the Venue. Last time I checked one of the things that was supposed to be coming in the next release was a
standard WSDL interface to the venue and venueserver.
This might be a good place to start looking at CVS and seeing if there are hints of those parts, and how to use them if they're
showing up.
--Ivan
> -----Original Message-----
> From: Derek Piper [mailto:dcpiper at indiana.edu]
> Sent: Wednesday, April 13, 2005 9:48 AM
> To: judson at mcs.anl.gov
> Cc: ag-tech at mcs.anl.gov; 'Adam Taylor'
> Subject: Re: [AG-TECH] AG security and multicast ?
> Hi,
> Since the 'brainstorming' appears to have died down a
> lot.. What about a published API for interacting with the
> venue server? Then we can all go write our tools/add-ons and
> be happy. Good ones can be incorporated into the main AG
> software, i.e. pass codes etc.
> Derek
> Ivan R. Judson wrote:
> > The beauty of Adam's suggestion is that it's exactly what
> the AG team
> > has been trying to get enough time to build. This is the
> kind of work
> > we'd like to see -- but I don't believe the NCSA scheduler has been
> > released yet for others to hack on it. The work I believe
> is a small
> > amount using the existing interfaces that are available.
> > If this can't be done in short order, I support Brian's
> point that for
> > most users a passcode/password -- similar to what is used by
> > conference calls or web meeting software, should be sufficient _to
> > gain access_ to the venue (to get past the bouncer), but
> it's really
> > of *no* use if the communication within the venue isn't
> secure -- then
> > as Jennifer points out, you're only relying on obscurity.
> > Who wants to hack on the scheduling software (either NCSA's
> or a new one)?
> > That's where the interesting "automation" is. It won't
> solve all the
> > ad-hoc stuff, but it'd go a long way towards solving a lot of the
> > mundane problems...
> > --Ivan
> >>From: owner-ag-tech at mcs.anl.gov
> >>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Adam Taylor
> >>Sent: Monday, April 11, 2005 11:01 AM
> >>To: ag-tech at mcs.anl.gov
> >>Subject: RE: [AG-TECH] AG security and multicast ?
> >>My two cents...
> >>To bad there wasn't a way that when you go to confirm you
> reservation
> >>in the AG Scheduler you must enter the DN of the site you
> will be at
> >>to confirm your reservation. Then, 5 min or so before the meeting
> >>starts, a background process (something that can talk to the venue
> >>server and scheduler) reads in the DNs from the scheduler for that
> >>room and time and sets the ACL for that room for that given
> scheduled
> >>time block. When that meeting is over, the background
> process removes
> >>that ACL for that room and creates another one for the next
> meeting in
> >>that room. If there is more then 30 min or so between
> meetings then
> >>the background process just removes the ACL for that period
> of time.
> >>Just make sure all rooms are encrypted (different key per
> meeting or
> >>something like that) and that should make it pretty secure.
> >>At least in my head it does :-)
> >>Adam Taylor
> >>Computing Center
> >>University of Louisiana at Monroe
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111 IRI 323,
> School of Informatics Indiana University, Bloomington, Indiana
