[AG-TECH] FW: Videum problem
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Sep 29 14:15:55 CDT 2004
The service updates are new zip files, so you can just place them in
C:\Program Files\AGTk2.3\NodeServices and use them.
If you are trying to update with .py files from CVS, you'd have to
update the .zip file as you said, and then increment the version number
in the .svc file.  I would recommend you stick with the package updates
that are provided, though.
Tom
Fred Dech wrote:
> hi Tom.
> what is the proper way to incorporate those CVS .py files into
> AGTk?  unzip the Service.zip, replace with new .py, rezip?
> thanks.
> --fred
> On Wed, Sep 29, 2004 at 09:56AM, Thomas D. Uram said:
>>Those files are in place now.  They set the Source number (0 for
>>vic.exe0, 1 for vic.exe1, etc.) and the Width and Height to h261 values
>>(352x288).
>>Let me know how they work for you.
>>Tom
>>Randy Groves wrote:
>>>Don't know about all you folks, but the two URLS come up 404 for me.  Is
>>>this patch included in CVS?  Or are these updated service files
>>>available somewhere else?
>>>-randy
>>>At 12:15 PM 9/24/2004, Fred Dech wrote:
>>>>oh Marcus.
>>>>i completely forgot about this.  it's important.  i haven't tried these
>>>>patches yet because my system was working like i wanted already.
>>>>----- Forwarded message from "Thomas D. Uram" <turam at mcs.anl.gov> -----
>>>>Okay, thanks to the logs I got from the two of you, I understand the
>>>>problem you've run into.  The videum card has four drivers that can be
>>>>used by vic; unfortunately, each driver can be mapped to any one of the
>>>>capture devices on the card, as indicated by the Source value in the
>>>>registry.
>>>>The video producer service (and video service) attempt to map the
>>>>drivers to capture devices directly (1 to 1, 2 to 2, etc.), which gives
>>>>you a convenient reference (i.e., WnvVdm32.dll 1-blahblah always shows
>>>>you the same camera).  The code was failing to map, but not fatally
>>>>(that's by design ;-).
>>>>The flaw is fixed in a newer VideoProducerService.zip and
>>>>VideoService.zip that you can get here, if you're interested:
>>>>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoProducerService.zip
>>>>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoService.zip
>>>>To use these, you can copy these files to
>>>>C:\Program Files\AGTk-2.3\NodeServices
>>>>If you've set the Source values properly, you really don't need to
>>>>update your services.  If you do try them, let me know your results.
>>>>Thanks,
>>>>Tom
>>>>----- End forwarded message -----
