[AG-TECH] FW: Videum problem
Fred Dech
fdech at uchicago.edu
Wed Sep 29 13:17:57 CDT 2004
hi Tom.
what is the proper way to incorporate those CVS .py files into
AGTk? unzip the Service.zip, replace with new .py, rezip?
thanks.
--fred
On Wed, Sep 29, 2004 at 09:56AM, Thomas D. Uram said:
> Those files are in place now. They set the Source number (0 for
> vic.exe0, 1 for vic.exe1, etc.) and the Width and Height to h261 values
> (352x288).
> Let me know how they work for you.
> Tom
> Randy Groves wrote:
> >Don't know about all you folks, but the two URLS come up 404 for me. Is
> >this patch included in CVS? Or are these updated service files
> >available somewhere else?
> >-randy
> >At 12:15 PM 9/24/2004, Fred Dech wrote:
> >>oh Marcus.
> >>i completely forgot about this. it's important. i haven't tried these
> >> patches yet because my system was working like i wanted already.
> >>----- Forwarded message from "Thomas D. Uram" <turam at mcs.anl.gov> -----
> >>Okay, thanks to the logs I got from the two of you, I understand the
> >>problem you've run into. The videum card has four drivers that can be
> >>used by vic; unfortunately, each driver can be mapped to any one of the
> >>capture devices on the card, as indicated by the Source value in the
> >>registry.
> >>The video producer service (and video service) attempt to map the
> >>drivers to capture devices directly (1 to 1, 2 to 2, etc.), which gives
> >>you a convenient reference (i.e., WnvVdm32.dll 1-blahblah always shows
> >>you the same camera). The code was failing to map, but not fatally
> >>(that's by design ;-).
> >>The flaw is fixed in a newer VideoProducerService.zip and
> >>VideoService.zip that you can get here, if you're interested:
> >>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoProducerService.zip
> >>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoService.zip
> >>To use these, you can copy these files to
> >>C:\Program Files\AGTk-2.3\NodeServices
> >>If you've set the Source values properly, you really don't need to
> >>update your services. If you do try them, let me know your results.
> >>Thanks,
> >>Tom
> >>----- End forwarded message -----
