[AG-TECH] FW: Videum problem
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Sep 29 09:56:10 CDT 2004
Those files are in place now.  They set the Source number (0 for
vic.exe0, 1 for vic.exe1, etc.) and the Width and Height to h261 values
(352x288).
Let me know how they work for you.
Tom
Randy Groves wrote:
> Don't know about all you folks, but the two URLS come up 404 for me.  Is
> this patch included in CVS?  Or are these updated service files
> available somewhere else?
> -randy
> At 12:15 PM 9/24/2004, Fred Dech wrote:
>> oh Marcus.
>> i completely forgot about this.  it's important.  i haven't tried these
>>  patches yet because my system was working like i wanted already.
>> ----- Forwarded message from "Thomas D. Uram" <turam at mcs.anl.gov> -----
>> Okay, thanks to the logs I got from the two of you, I understand the
>> problem you've run into.  The videum card has four drivers that can be
>> used by vic; unfortunately, each driver can be mapped to any one of the
>> capture devices on the card, as indicated by the Source value in the
>> registry.
>> The video producer service (and video service) attempt to map the
>> drivers to capture devices directly (1 to 1, 2 to 2, etc.), which gives
>> you a convenient reference (i.e., WnvVdm32.dll 1-blahblah always shows
>> you the same camera).  The code was failing to map, but not fatally
>> (that's by design ;-).
>> The flaw is fixed in a newer VideoProducerService.zip and
>> VideoService.zip that you can get here, if you're interested:
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoProducerService.zip
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoService.zip
>> To use these, you can copy these files to
>> C:\Program Files\AGTk-2.3\NodeServices
>> If you've set the Source values properly, you really don't need to
>> update your services.  If you do try them, let me know your results.
>> Thanks,
>> Tom
>> ----- End forwarded message -----
