[AG-TECH] FW: Videum problem
    Randy Groves
    randy.groves at boeing.com
    Tue Sep 28 18:11:35 CDT 2004
Don't know about all you folks, but the two URLS come up 404 for me.  Is
this patch included in CVS?  Or are these updated service files available
somewhere else?
-randy
At 12:15 PM 9/24/2004, Fred Dech wrote:
>oh Marcus.
>i completely forgot about this.  it's important.  i haven't tried these
>  patches yet because my system was working like i wanted already.
>----- Forwarded message from "Thomas D. Uram" <turam at mcs.anl.gov> -----
>Okay, thanks to the logs I got from the two of you, I understand the
>problem you've run into.  The videum card has four drivers that can be
>used by vic; unfortunately, each driver can be mapped to any one of the
>capture devices on the card, as indicated by the Source value in the
>registry.
>The video producer service (and video service) attempt to map the
>drivers to capture devices directly (1 to 1, 2 to 2, etc.), which gives
>you a convenient reference (i.e., WnvVdm32.dll 1-blahblah always shows
>you the same camera).  The code was failing to map, but not fatally
>(that's by design ;-).
>The flaw is fixed in a newer VideoProducerService.zip and
>VideoService.zip that you can get here, if you're interested:
>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoProducerService.zip
>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VideoService.zip
>To use these, you can copy these files to
>C:\Program Files\AGTk-2.3\NodeServices
>If you've set the Source values properly, you really don't need to
>update your services.  If you do try them, let me know your results.
>Thanks,
>Tom
>----- End forwarded message -----
