[AG-TECH] Specs for a 2.3 room node
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue Sep 28 15:46:03 CDT 2004
AG 2.3 detects the multiple capture drivers installed for the Videum and
the Osprey cards, and allows the video producer to be configured to use
them.  I've used this videoproducer on a dual Osprey pig node here at
Argonne with no problems.
Tom
Fred Dech wrote:
> i have the Videum 4400 working well under AG 2.3, although there seem to
> still be a few outstanding issues.
> if you got a machine with enough PCI slots, 'probably need to go through
> a custom system house like Monarch, you might also be able to run
> with 4 Ospreys.  i'm not sure if anyone is doing this from a single box
> node.  if they are, i'd be interested in knowing.
> --fred
> On Thu, Sep 23, 2004 at 02:47PM, Osland, CD (Chris)  said:
>>I think you'll find that the latest AG 2.3 distribution, as of a
>>few days ago, makes a decent job of setting up a Winnov Videum 4400
>>card, but that's just what I gather from looking at ag-tech.  That's
>>the card which we've found fine under AG 2.1.2.
>>Cheers
>>Chris
>>____________________________________________________________________
>>Chris Osland                                               Office tel: +44
>>(0) 1235 446565
>>Digital Media and Access Grid                          Medialab tel: +44 (0)
>>1235 446459
>>BIT Department                                     Access Grid room tel: +44
>>(0) 1235 445666
>>e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
>>(0) 1235 445597
>>CCLRC Rutherford Appleton Laboratory (Bldg. R18)
>>Chilton, DIDCOT, Oxon OX11 0QX, UK
>>[The contents of this email are confidential and are for the use of the
>>intended recipient only.
>>If you are not the intended recipient do not take any action on it or show
>>it to anyone else,
>>but return this email to the sender and delete your copy of it.]
>>>-----Original Message-----
>>>From: Monika Rabarison [mailto:monika.k.rabarison at ccaix.jsums.edu]
>>>Sent: 23 September 2004 14:32
>>>To: Osland, CD (Chris)
>>>Cc: ag-tech at mcs.anl.gov
>>>Subject: RE: [AG-TECH] Specs for a 2.3 room node
>>>It is just that we currently have the old 4 machine node.
>>>I did not know the multiple stream video cards issue is
>>>handled with 2.3 now. In that case, I am thinking about a
>>>single machine
>>>running XP. Any specific cards that I should use?
>>>Thanks,
>>>Monika
>>>On Thu, 23 Sep 2004, Osland, CD (Chris)  wrote:
>>>>I'm wondering why you want to go for a 3 computer solution?  Do you
>>>>want to run different operating systems for different functions.
>>>>As far as I can tell from personal experience and feedback on the
>>>>list, single computer (twin Xeon or twin Athlon, 2.8 GHz or above)
>>>>systems can do everything.  It's taken a time to get AG 2.3 support
>>>>for multiple stream video cards into the distribution (the original
>>>>registery fix we circulated in March was for AG 2.1.2), but for
>>>>me the ease of a single machine, single network connection, makes
>>>>a 3 machine solution look like hard work.
>>>>Cheers
>>>>Chris
>>>>Chris Osland
>>>Office tel: +44
>>>>(0) 1235 446565
>>>>1235 446459
>>>Grid room tel: +44
>>>>(0) 1235 445666
>>>        Fax: +44
>>>>(0) 1235 445597
>>>the use of the
>>>>it to anyone else,
>>>>>From: owner-ag-tech at mcs.anl.gov
>>>[mailto:owner-ag-tech at mcs.anl.gov]On
>>>>>Behalf Of Monika Rabarison
>>>>>Sent: 22 September 2004 18:23
>>>>>To: ag-tech at mcs.anl.gov
>>>>>Subject: [AG-TECH] Specs for a 2.3 room node
>>>>>Hi All,
>>>>>What would be the best hardware specs
>>>>>and OS for building a room node with AGTk 2.3?
>>>>>Let say it will be a 3 machine node (display, video capture,
>>>>>audio capture).
>>>>>Any insight would be most appreciated.
>>>>>Thanks,
>>>>>Monika
