[AG-TECH] Specs for a 2.3 room node
    Fred Dech
    fdech at uchicago.edu
    Thu Sep 23 11:15:46 CDT 2004
i have the Videum 4400 working well under AG 2.3, although there seem to
still be a few outstanding issues.
if you got a machine with enough PCI slots, 'probably need to go through
a custom system house like Monarch, you might also be able to run
with 4 Ospreys.  i'm not sure if anyone is doing this from a single box
node.  if they are, i'd be interested in knowing.
--fred
On Thu, Sep 23, 2004 at 02:47PM, Osland, CD (Chris)  said:
> I think you'll find that the latest AG 2.3 distribution, as of a
> few days ago, makes a decent job of setting up a Winnov Videum 4400
> card, but that's just what I gather from looking at ag-tech.  That's
> the card which we've found fine under AG 2.1.2.
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland                                               Office tel: +44
> (0) 1235 446565
> Digital Media and Access Grid                          Medialab tel: +44 (0)
> 1235 446459
> BIT Department                                     Access Grid room tel: +44
> (0) 1235 445666
> e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
> (0) 1235 445597
> CCLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the use of the
> intended recipient only.
> If you are not the intended recipient do not take any action on it or show
> it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > -----Original Message-----
> > From: Monika Rabarison [mailto:monika.k.rabarison at ccaix.jsums.edu]
> > Sent: 23 September 2004 14:32
> > To: Osland, CD (Chris)
> > Cc: ag-tech at mcs.anl.gov
> > Subject: RE: [AG-TECH] Specs for a 2.3 room node
> > It is just that we currently have the old 4 machine node.
> > I did not know the multiple stream video cards issue is
> > handled with 2.3 now. In that case, I am thinking about a
> > single machine
> > running XP. Any specific cards that I should use?
> > Thanks,
> > Monika
> > On Thu, 23 Sep 2004, Osland, CD (Chris)  wrote:
> > > I'm wondering why you want to go for a 3 computer solution?  Do you
> > > want to run different operating systems for different functions.
> > > As far as I can tell from personal experience and feedback on the
> > > list, single computer (twin Xeon or twin Athlon, 2.8 GHz or above)
> > > systems can do everything.  It's taken a time to get AG 2.3 support
> > > for multiple stream video cards into the distribution (the original
> > > registery fix we circulated in March was for AG 2.1.2), but for
> > > me the ease of a single machine, single network connection, makes
> > > a 3 machine solution look like hard work.
> > > Cheers
> > > Chris
> > > Chris Osland
> > Office tel: +44
> > > (0) 1235 446565
> > > 1235 446459
> > Grid room tel: +44
> > > (0) 1235 445666
> >         Fax: +44
> > > (0) 1235 445597
> > the use of the
> > > it to anyone else,
> > > > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov]On
> > > > Behalf Of Monika Rabarison
> > > > Sent: 22 September 2004 18:23
> > > > To: ag-tech at mcs.anl.gov
> > > > Subject: [AG-TECH] Specs for a 2.3 room node
> > > > Hi All,
> > > > What would be the best hardware specs
> > > > and OS for building a room node with AGTk 2.3?
> > > > Let say it will be a 3 machine node (display, video capture,
> > > > audio capture).
> > > > Any insight would be most appreciated.
> > > > Thanks,
> > > > Monika
