[AG-TECH] RAT not starting up in AG 2.3 on Win XP
    Eric Olson
    eolson at mcs.anl.gov
    Fri Sep 24 12:01:15 CDT 2004
Hi Wesley,
Maybe you've checked this, but often rat not starting is a symptom of no
multicast available or a firewall blocking multicast.
You could try unicast only and see if it helps by: turning off audio in
the menu before going to a venue, then going to a venue and switching to
unicast (assuming there is a bridge available), and finally turning on
audio again.  If this unicast method works, then multicast connectivity is
likely the problem -- although I'm not sure if that helps test firewall
issues or not.
Eric
On Fri, 24 Sep 2004, Wesley Skoczen wrote:
> This is AG 2.3 installation on Laptop Gateway M675, with Windows XP Home
> edition.
> AG 2.3 runs almost normally, but with one exception RAT program is not
> showing up.
> In Windows Task Manager rat, ratmedia and ratui are listed but RAT
> window is not showing up on the desktop.
> When I run RAT for the first time after fresh restart from the command
> line (i.e.: rat 224.2.211.167/16964) it opens a new window.
> When I close the RAT window I can't start RAT anymore. Windows Task
> Manager shows that ratmedia is running.
> I cannot end this process in any way other then by restarting Windows.
> In fact each time I start rat, it adds extra rat, ratmedia and ratui
> processes,
> I can end rat and ratui but it is not possible to end ratmedia process.
> I have also installed rat-4.2.24-ipv6-win2k and it is showing the same
> behavior, as version included in AG Toolkit.
> Any help will be appreciated,
> Thank You
>     Wesley
> Wesley Skoczen
> tel. 905 845 9430 x8704
