[AG-TECH] about Hauppuage WINTV Capture Card
    Russ Wolf
    russ at bu.edu
    Wed Sep 22 09:58:00 CDT 2004
Zeppy,
You need to build the V4L2 drivers in to your older kernel.
the starting place for this is:
http://linux.bytesex.org/v4l2/drivers.html
     http://linux.bytesex.org/v4l2/cx88.html
     http://dl.bytesex.org/releases/video4linux/
about cx88
This is a v4l2 device driver for TV cards based on the conexant 2388x
chip family.
Most prominent piece of hardware are the recent Hauppauge WinTV cards.
More and more Vendors are switching now through ...
Driver releases are available for download right here. Note that the
cx88 driver also is included in the 2.6.x kernels.
	--Russ Wolf, Boston University
Zeppy B. Vilan wrote:
> Hello everybody,
> Does anybody use this type of chipset of the particular capture card
> which is Hauppauge WINTV and the chipset name is:
> CONEXANT
> BROADCAST DECODER
> CX23880-19
> FC8116.2
> 0350 KOREA
> anybody has a solution running with redhat 7.3 for video machine for the
> accessgrid. thank you for your support regarding this problem. thank you
> and have a good day everyone.
> cheers,
> zeppy
> __________________________________________
> Zeppy B. Vilan
> Science Research Specialist I
> PREGINET Network-Multimedia Over Ip Group
> Communications Engineering Division
> Advanced Science and Technology Institute
> C.P. Garcia Avenue, UP Technopark
> Diliman, Quezon City
> Phone: (+63 2) 426 9766 / 67
> Fax:   (+63 2) 426 9756
> Email: zeppy at asti.dost.gov.ph <mailto:zeppy at asti.dost.gov.ph>
