[AG-TECH] Mac OS X Install and Certificate Request
Jeffrey Bary
Jeffrey.Bary at nyu.edu
Fri Sep 17 09:50:30 CDT 2004
I did get the email that my certificate is ready but now the pending
certificate has disappeared from my Certificate Manager.
-Jeff
>I submitted a bugzilla report (#1165) and I tried your suggestion.
>After deleting the certrepo directory and accessing the Certificate
>Manager as you suggest, all went well and I'm waiting for a new
>certificate.
>-Jeff
>>Hi Jeffrey,
>>Can you please file a bug in bugzilla (bugzilla.mcs.anl.gov/accessgrid)
>>and attach your log files? The logs are located in
>>/Users/<username>/.AccessGrid/Logs
>>Here are a couple things to try:
>> - try removing your /Users/<username>/.AccessGrid/Config/certrepo
>>directory and try requesting another certificate.
>> - If you started the certificate manager from the launcher, see if it
>>helps to start it from the VenueClient through Preferences->Certificate
>>Manager.
>>Eric
>>On Thu, 16 Sep 2004, Jeffrey Bary wrote:
>>> I installed the Mac OS X version 2.3 of the Access Grid Toolkit and
>>> then I went to request a certificate using the certificate wizard. It
>>> worked fine until the last page that contains the message:
>>> Click 'Finish' to submit identity certificate request for Jeffrey
>>> Bary to Argonne. A confirmation e-mail will be sent, within 2
>>> business days, to Jeffrey.Bary at nyu.edu.
>>> I then pressed to "Finish" button and got the message:
>>> Error occurred. Certificate request cannot be completed.
>>> Any suggestions on how to proceed ?
>>> -Jeff
>>> Jeffrey Bary New York University phone: 212-998-3049
>>> Senior Arts Technologist 251 Mercer fax: 212-995-4120
>>> Arts Technology Group New York, NY 10012 internet:
>>> N Y U / I n f o r m a t i o n T e c h n o l o g y S e r v i c e s
>>> A c a d e m i c C o m p u t i n g S e r v i c e s
