[AG-TECH] Mac OS X Install and Certificate Request
    Jeffrey Bary
    Jeffrey.Bary at nyu.edu
    Thu Sep 16 14:33:56 CDT 2004
I submitted a bugzilla report (#1165) and I tried your suggestion.
After deleting the certrepo directory and accessing the Certificate
Manager as you suggest, all went well and I'm waiting for a new
certificate.
-Jeff
>Hi Jeffrey,
>Can you please file a bug in bugzilla (bugzilla.mcs.anl.gov/accessgrid)
>and attach your log files?  The logs are located in
>/Users/<username>/.AccessGrid/Logs
>Here are a couple things to try:
>  - try removing your /Users/<username>/.AccessGrid/Config/certrepo
>directory and try requesting another certificate.
>  - If you started the certificate manager from the launcher, see if it
>helps to start it from the VenueClient through Preferences->Certificate
>Manager.
>Eric
>On Thu, 16 Sep 2004, Jeffrey Bary wrote:
>>  I installed the Mac OS X version 2.3 of the Access Grid Toolkit and
>>  then I went to request a certificate using the certificate wizard. It
>>  worked fine until the last page that contains the message:
>>  Click 'Finish' to submit identity certificate request for Jeffrey
>>  Bary to Argonne.  A confirmation e-mail will be sent, within 2
>>  business days, to Jeffrey.Bary at nyu.edu.
>>  I then pressed to "Finish" button and got the message:
>>  Error occurred. Certificate request cannot be completed.
>>  Any suggestions on how to proceed ?
>>  -Jeff
>>  Jeffrey Bary              New York University     phone:  212-998-3049
>>  Senior Arts Technologist  251 Mercer                fax:  212-995-4120
>>  Arts Technology Group     New York, NY 10012   internet:
>>        N Y U  /  I n f o r m a t i o n  T e c h n o l o g y  S e r v i c e s
>>               A c a d e m i c   C o m p u t i n g   S e r v i c e s
