[AG-TECH] Mac OS X Install and Certificate Request
Eric Olson
eolson at mcs.anl.gov
Thu Sep 16 13:11:10 CDT 2004
Hi Jeffrey,
Can you please file a bug in bugzilla (bugzilla.mcs.anl.gov/accessgrid)
and attach your log files? The logs are located in
/Users/<username>/.AccessGrid/Logs
Here are a couple things to try:
- try removing your /Users/<username>/.AccessGrid/Config/certrepo
directory and try requesting another certificate.
- If you started the certificate manager from the launcher, see if it
helps to start it from the VenueClient through Preferences->Certificate
Manager.
Eric
On Thu, 16 Sep 2004, Jeffrey Bary wrote:
> I installed the Mac OS X version 2.3 of the Access Grid Toolkit and
> then I went to request a certificate using the certificate wizard. It
> worked fine until the last page that contains the message:
> Click 'Finish' to submit identity certificate request for Jeffrey
> Bary to Argonne. A confirmation e-mail will be sent, within 2
> business days, to Jeffrey.Bary at nyu.edu.
> I then pressed to "Finish" button and got the message:
> Error occurred. Certificate request cannot be completed.
> Any suggestions on how to proceed ?
> -Jeff
> Jeffrey Bary New York University phone: 212-998-3049
> Senior Arts Technologist 251 Mercer fax: 212-995-4120
> Arts Technology Group New York, NY 10012 internet: Jeffrey.Bary at nyu.edu
> N Y U / I n f o r m a t i o n T e c h n o l o g y S e r v i c e s
> A c a d e m i c C o m p u t i n g S e r v i c e s
