[AG-TECH] Gnome launchers in FC2
    Jim Miller
    millerjw at psc.edu
    Wed Sep 15 14:58:04 CDT 2004
Nope, the only thing running on the linux box is AGServiceManager.py.
The VenueClient is running on the control(display windows xp) machine.
Jim
Michael Miller wrote:
> So you are running the VenueClient on the same machine as the separate
> AGServiceManager?
> If so, then yes, you will have a problem running the VenueClient with
> the --personalNode flag as that will cause an AGServiceManager.py
> instance to attempt to use port 11000.  Which will cause it to fail
> because the port is already in use by the separate AGServiceManager.
> Try setting the command in the startup app to:
> AGServiceManager.py -p 12000
> or whatever other port you want.
> If you're not using the --personalNode flag when running the venue
> client, I would file it as a bug because the venue client should not be
> launching a service manager if the flag is not there.
> Michael Miller
> NCSA
> At 12:44 PM 9/15/2004, Jim Miller wrote:
>> Just tried that... didn't work.  The AGServiceManager dies as soon as
>> I bring up the Venue Client on the control box.... Same issue.
>> Jim
>>> Jim,
>>> Use gnome-session-properties to set up a "Startup Application".  I
>>> just entered AGServiceManager.py  in the command box and logged
>>> out/logged in and it works.
>>> Michael Miller
>>> NCSA
>>> At 03:36 PM 9/14/2004, Jim Miller wrote:
>>>> I am having problems with the launchers in Gnome.  If I open an
>>>> xterm or a gnome-terminal and run Service Manager by physically
>>>> typing AGServiceManager.py everything works fine.  However, If I try
>>>> to run servicemanager from the menu items or create a launcher
>>>> myself, the AGServiceManager will run and listen on port 11000, but
>>>> as soon as the VenueClient tries to communicate with the
>>>> ServiceManager, the terminal window disappears and the
>>>> AGServiceManager.py script dies.  I have tried creating Gnome
>>>> application launchers for the AGServiceManager.py script as well as
>>>> created a launcher to run just a basic xterm that runs
>>>> AGServiceManager (xterm -e AGServiceManager.py)
>>>> I get the same result for both.
>>>> Any Ideas?
>>>> Thanks,
>>>> Jim
>>> Thanx,
>>> Michael Miller
>>> System Engineer
>>> Visualization Technology Support
>>> Computing and Data Management
>>> National Center for Supercomputing Applications
>>> University of Illinois - UC
>>> 217-649-0747
>>> "If you're clear in your vision and trust the people in your team
>>> with clear objectives, they will invariably do their best to achieve
>>> everything desired, and usually deliver everything you could have
>>> hoped for and even more." -Paul Debevec
> Thanx,
> Michael Miller
> System Engineer
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> everything desired, and usually deliver everything you could have hoped
