[AG-TECH] Gnome launchers in FC2
    Michael Miller
    mimiller at ncsa.uiuc.edu
    Wed Sep 15 13:31:57 CDT 2004
So you are running the VenueClient on the same machine as the separate
AGServiceManager?
If so, then yes, you will have a problem running the VenueClient with the
--personalNode flag as that will cause an AGServiceManager.py instance to
attempt to use port 11000.  Which will cause it to fail because the port is
already in use by the separate AGServiceManager.
Try setting the command in the startup app to:
AGServiceManager.py -p 12000
or whatever other port you want.
If you're not using the --personalNode flag when running the venue client,
I would file it as a bug because the venue client should not be launching a
service manager if the flag is not there.
Michael Miller
NCSA
At 12:44 PM 9/15/2004, Jim Miller wrote:
>Just tried that... didn't work.  The AGServiceManager dies as soon as I
>bring up the Venue Client on the control box.... Same issue.
>Jim
>Michael Miller wrote:
>>Jim,
>>Use gnome-session-properties to set up a "Startup Application".  I just
>>entered AGServiceManager.py  in the command box and logged out/logged in
>>and it works.
>>Michael Miller
>>NCSA
>>At 03:36 PM 9/14/2004, Jim Miller wrote:
>>>I am having problems with the launchers in Gnome.  If I open an xterm or
>>>a gnome-terminal and run Service Manager by physically typing
>>>AGServiceManager.py everything works fine.  However, If I try to run
>>>servicemanager from the menu items or create a launcher myself, the
>>>AGServiceManager will run and listen on port 11000, but as soon as the
>>>VenueClient tries to communicate with the ServiceManager, the terminal
>>>window disappears and the AGServiceManager.py script dies.  I have tried
>>>creating Gnome application launchers for the AGServiceManager.py script
>>>as well as created a launcher to run just a basic xterm that runs
>>>AGServiceManager (xterm -e AGServiceManager.py)
>>>I get the same result for both.
>>>Any Ideas?
>>>Thanks,
>>>Jim
>>Thanx,
>>Michael Miller
>>System Engineer
>>Visualization Technology Support
>>Computing and Data Management
>>National Center for Supercomputing Applications
>>University of Illinois - UC
>>217-649-0747
>>"If you're clear in your vision and trust the people in your team with
>>clear objectives, they will invariably do their best to achieve
>>everything desired, and usually deliver everything you could have hoped
>>for and even more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
