[AG-TECH] shared apps again
    Dave Semeraro
    semeraro at ncsa.uiuc.edu
    Tue Sep 14 11:28:54 CDT 2004
Thanks Suzanne,
I sprinkled liberal amounts of try/except pairs in the code and things
started to work. I am
not sure what this fixed except that I no longer get the datastore errors I
was getting. I have
found a 2.3 venue server to work with so the original connection error is
gone. I am now wading
through the errors that were waiting on the other side of the datastore
problem. I can upload and
download images and am working on the markup part of the application. It
should be
ready for use in a couple of days.
Thanks again.
Dave
At 06:11 PM 9/13/2004 -0500, Susanne Lefvert wrote:
>Hello Dave,
>The exception you are seeing when connecting to a venue should not stop
>your application from working.  Since you are connecting to a 2.1.2
>server the application first tries to join the venue with an argument,
>fails, logs the exception, and then enters the with a legacy call without
>arguments.  However, I believe the data store errors that are printed
>in your log files are causing your application to fail.  Try putting
>try/excepts around all your dataStoreClient calls and see if you can
>connect better.
>Regards,
>Susanne
>On Mon, 13 Sep 2004, Dave Semeraro wrote:
> > Hi techies
> > I am back at shared app development. I am in the process of trying to port
> > the shared image
> > thing over to the AG2.3. I downloaded the new software and installed it. I
> > did a pretty complete
> > rewrite of the AGBasicImage.py app following the shared app developers
> > guide in the wiki. It
> > has the shared browser look and feel now. Except for the fact that it
> > doesnt work. I followed the
> > shared app gotcha's in the wiki to try to run the application as a console
> > application so I could
> > get some debug output. I got a little of that. The main problem seems
> to be
> > connecting to
> > the venue. I have attached the shared image code and the venueclient.log
> > and the shared image
> > log file from the most recent run. I get some crazy errors in the shared
> > image file that I
> > just cant track down. There may be other bugs in the application that I
> > have not gotten to yet
> > but I cant find them if I cant connect to the venue. So could someone give
> > me a tip as to what
> > I am doing wrong here?
> > Regards,
> > Dave
> > Dave Semeraro Ph.D.
> > Visualization and Virtual Environments Group
> > NCSA University of Illinois
> > 605 E. Springfield Ave.
> > Champaign, IL 61820
> > Semeraro at ncsa.uiuc.edu
> > (217) 244-1852
Dave Semeraro Ph.D.
Champaign, IL 61820
(217) 244-1852
