[AG-TECH] Building failure - strange behaviour with pyGlobus
    Ivan R. Judson
    judson at mcs.anl.gov
    Fri Sep  3 06:12:58 CDT 2004
Hi Joseph,
(I've cc'd the pyglobus mailing list since this is actually a
pyglobus/globus problem, and since it's happening during the attempt to
build packages it's not a "user" level error, but a developer problem. The
combination of those two facts are the reasons we closed the bug yesterday.
I'm sorry if that wasn't clearer from the email you got about it.
But: it looks like there's a problem with either your globus install, since
globus-makefile-header is a script that's used to generate compilation flags
for programs that use globus. Are you absolutely sure you've run whatever
post-install scripts need to be run for globus to correctly configure
itself?
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Joseph
> Sent: Friday, September 03, 2004 12:35 AM
> To: 'ag-tech'
> Subject: [AG-TECH] Building failure - strange behaviour with pyGlobus
> Hi
> In fact, since the Beta2 release, my build isn't working
> anymore. The pyGlobus module isn't build. In my build output,
> I find a lot of :
> "Building pyGlobus
> Checking for which modules to build
> Checking the util module
> Missing dependency to build the util package.
> This package is required to build all of pyGlobus.
> The following is the error message from globus-makefile-header.
> ('No packages were found that matched your query!\n',) Now
> exiting from the build."
> And so on, then
> "ImportError: No module named pyGlobus"
> Nothing had changed between the Beta1 and the Beta2 on my pc,
> so I filed a bug report but apparently it wasn't one, the
> trouble should be with my installation of environment variables.
> However, just to be sure, I have
> - resintalled gpt and globus : as usual, only the
> globus_trusted_ca_42864e48_setup-noflavor-pgm appears not to
> be correctly configurated after a gpt-postinstall and then
> gpt-verify, but I was told before it's all right,
> - checked the GPT_LOCATION and GLOBUS_LOCATION (they are set).
> So I looked closer at the error, this globus-makefile-header.
> I have found a very strange behaviour : when I change the
> line 230 in /usr/lib/globus/bin/globus-makefile-header the
> behaviour of the build process is deeply affected even if a
> just add the word "TEST" in the output string. In brief, I
> just change the line 230 from :
> 	printf("No packages were found that matched your
> query!\n"); to :
> 	printf("TEST No packages were found that matched your
> query!\n");
> The new behaviour is astonishing, I now have :
> "Building pyGlobus
> The util module will be built
> Checking the ftpClient module
> The ftpClient module will be built
> Checking the ftpControl module
> The ftpControl module will be built
> Checking the gassCache module
> Traceback (most recent call last):
>    File "setup.py", line 915, in ?
>      pyModList, eModList, swigList = build_module_lists()
>    File "setup.py", line 247, in build_module_lists
>      check_gassCache(pyModList, eModList, swigList)
>    File "setup.py", line 425, in check_gassCache
>      major, minor = check_version(dep)
> TypeError: unpack non-sequence
> Checking the io module
> using version 4.0
> The io module will be built
> Checking the security module
> using version 3.5
> The security module will be built
> swig -python -noproxy -DHAVE_CONFIG_H
> -I/usr/include/python2.3 -o ./src/io_wrap.c ./src/io-4.0.i
> -I/usr/include/python2.3 -o ./src/gss_wrap.c ./src/gss.i swig
> -python -noproxy -DHAVE_CONFIG_H -I/usr/include/python2.3 -o
> ./src/gsi_wrap.c ./src/gsi-3.5.i swig -python -noproxy
> -DHAVE_CONFIG_H -I/usr/include/python2.3 -o ./src/util_wrap.c
> ./src/util.i running build"
> Do you have any clue of what I'm doing wrong ? I just don't
> understand !
> Cheers,
>   Joseph
