[AG-TECH] Fedora Core 2 and AG 2.3
    Jim Miller
    millerjw at psc.edu
    Wed Sep  1 12:54:17 CDT 2004
I am having the exact same problem today.  I can bring up the venue
client in the main lobby, navigate to the institution venues and back to
the main lobby, but when I try to access the Test Room the Venue client
hangs.
Jim
Todd Zimmerman wrote:
> You may want to try temporarily disabling your firewall also to see if
> that is the problem.
> My firewall currently accepts:
> established  / related connections
> TCP port 22 (don't think you specifically need this for AG)
> udp port 47000 (rat gui)
> udp ports > 50000 (RTP streams)
> Plus, I'm only on unicast - so if you use multicast you'll need to
> specificy that traffic also.
> Todd
> Jeremy Mann wrote:
>> I am having no luck at ALL whatsoever with 2.3 and Fedora Core 2. When
>> going to a venue, the client just hangs. I've even tried to start it from
>> command line thinking I'd get an error message, but I don't. Has anybody
>> seen this with Fedora Core 2?
