[AG-TECH] Fedora Core 2 and AG 2.3
Fred Dech
fdech at uchicago.edu
Fri Sep 17 16:01:43 CDT 2004
'happened to me, too on a windows box. that's why they call it the 'Test
Room,' i guess.
but Jeremy's problem definately sounds more like it has to do with the
~mysterious~ iptables.
--fred
On Wed, Sep 01, 2004 at 01:54PM, Jim Miller said:
> I am having the exact same problem today. I can bring up the venue
> client in the main lobby, navigate to the institution venues and back to
> the main lobby, but when I try to access the Test Room the Venue client
> hangs.
> Jim
> Todd Zimmerman wrote:
> >You may want to try temporarily disabling your firewall also to see if
> >that is the problem.
> >My firewall currently accepts:
> >established / related connections
> >TCP port 22 (don't think you specifically need this for AG)
> >udp port 47000 (rat gui)
> >udp ports > 50000 (RTP streams)
> >Plus, I'm only on unicast - so if you use multicast you'll need to
> >specificy that traffic also.
> >Todd
> >Jeremy Mann wrote:
> >>I am having no luck at ALL whatsoever with 2.3 and Fedora Core 2. When
> >>going to a venue, the client just hangs. I've even tried to start it from
> >>command line thinking I'd get an error message, but I don't. Has anybody
> >>seen this with Fedora Core 2?
