[AG-TECH] Shared Presentation Log problem info **URGENT**
    Randy Groves
    randy.groves at boeing.com
    Mon Oct  4 19:50:24 CDT 2004
Just tried this again, after re-installing the FC2 venue server.  I open
the shared presentation, click on 'Take control' and attempt to get the ppt
file from the venue.  The drop down box drops down but is empty.  And then
I attempt to upload a local file.  Here's the log from an attempt against a
freshly installed FC2 venue server:
10/04/04 17:48:41 508 Toolkit     toolkit.py:90 DEBUG Initializing AG
Toolkit version 2.3
10/04/04 17:48:41 508 Toolkit     toolkit.py:132 INFO  Logfile Name:
SharedPresentation.log
10/04/04 17:48:41 508 Toolkit     config.py:196 DEBUG Using
GLOBUS_HOSTNAME=darklockxp.nw.nos.boeing.com as set in the environment
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:257
DEBUG Opened repository C:\Documents and Settings\grovesr\Application
Data\AccessGrid\Config\certRepo
10/04/04 17:48:41 508 Toolkit     toolkit.py:396 DEBUG Got repo.
10/04/04 17:48:41 508 Toolkit     toolkit.py:398 DEBUG looking in system ca
dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
10/04/04 17:48:41 508 Toolkit     toolkit.py:402 DEBUG Getting cert: 1c3f2ca8.0
10/04/04 17:48:41 508 Toolkit     toolkit.py:407 WARNING Not importing cert
C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
10/04/04 17:48:41 508 Toolkit     toolkit.py:402 DEBUG Getting cert: 45cc9e80.0
C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
10/04/04 17:48:41 508 Toolkit     toolkit.py:402 DEBUG Getting cert: d1b603c3.0
C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
10/04/04 17:48:41 508 Toolkit     toolkit.py:402 DEBUG Getting cert: f18fa857.0
C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
10/04/04 17:48:41 508 Toolkit     toolkit.py:411 DEBUG Init'ing globus.
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:734
DEBUG Configuring standard environment
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:802
DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=boeing.com/CN=Randall S Groves
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:873
DEBUG Initializing environment with proxy cert for /O=Access
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:907
DEBUG Looking for identity (unused) None
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:892
DEBUG Configuring for user proxy issued from /O=Access
10/04/04 17:48:41 508 CertificateManager     certificatemanager.py:895
DEBUG Proxy C:\DOCUME~1\grovesr\LOCALS~1\Temp\proxy will expire 10/04/04
22:49:46
10/04/04 17:48:41 508 Toolkit     toolkit.py:415 DEBUG Done with globus.
10/04/04 17:48:43 508 EventClient     eventclient.py:158 DEBUG Have
callback handle _60972802_p_callbackStruct
10/04/04 17:48:43 508 SharedPresentation     sharedpresentation.py:727
DEBUG Registering for events.
10/04/04 17:48:43 508 SharedPresentation     sharedpresentation.py:735
DEBUG Creating controller.
10/04/04 17:48:43 3124 SharedPresentation     sharedpresentation.py:810
DEBUG Got Event: local load venue None
10/04/04 17:48:43 3124 SharedPresentation     sharedpresentation.py:1432
DEBUG Method LocalLoadVenue called
10/04/04 17:48:44 3124 SharedPresentation     sharedpresentation.py:1511
DEBUG Got slide num: 1
10/04/04 17:48:54 508 SharedPresentation     sharedpresentation.py:900
DEBUG Method SendMaster called; flag=(1)
10/04/04 17:48:55 2696 EventClient     eventclient.py:177 DEBUG Read
Callback called arg=None handle=_18d32602_p_globus_io_handle_t result=(0,
None, None)  n=4
10/04/04 17:48:55 2696 EventClient     eventclient.py:229 DEBUG Freeing
callback _60972802_p_callbackStruct within callback
10/04/04 17:48:55 2696 EventClient     eventclient.py:238 DEBUG Have new
None, None)  n=352
10/04/04 17:48:55 2696 EventClient     eventclient.py:218 DEBUG finally
read enough data, wait=352 buflen=352
10/04/04 17:48:55 2696 EventClient     eventclient.py:253 DEBUG Invoking
callback <bound method SharedAppClient.HandleEvent of
<AccessGrid.SharedAppClient.SharedAppClient instance at 0x01C64670>>...
10/04/04 17:48:55 2696 EventClient     eventclient.py:259 DEBUG Invoking
<AccessGrid.SharedAppClient.SharedAppClient instance at 0x01C64670>>...done
10/04/04 17:48:55 2696 EventClient     eventclient.py:261 INFO  No callback
for Set application data!
10/04/04 17:48:55 2696 EventClient     eventclient.py:329 INFO  Got
callback for Set application data event!
10/04/04 17:48:55 2696 EventClient     eventclient.py:224 DEBUG handleData
returns
None, None)  n=4
None, None)  n=194
read enough data, wait=194 buflen=194
10/04/04 17:48:55 2328 SharedPresentation     sharedpresentation.py:1055
DEBUG Method RecvMaster called
for master!
callback for master event!
10/04/04 17:48:55 3124 SharedPresentation     sharedpresentation.py:810
DEBUG Got Event: master ('000000ff668f37140082002a002300e4620',
'000000ff668f37140082002a002300e4620')
returns
10/04/04 17:48:55 3124 SharedPresentation     sharedpresentation.py:1183
DEBUG Method SetMaster called
None, None)  n=4
None, None)  n=1677
read enough data, wait=1677 buflen=1677
returns
10/04/04 17:48:56 508 DataStoreClient     datastoreclient.py:40
INFO  Connecting to venue https://venues2.rt.cs.boeing.com/Venues/default,
to get datastore information.
10/04/04 17:48:56 508 DataStoreClient     datastoreclient.py:45 ERROR
Couldn't get data store information from the venue.
Traceback (most recent call last):
   File "C:\Python23\Lib\site-packages\AccessGrid\DataStoreClient.py", line
43, in GetVenueDataStore
     ds = vproxy.GetDataStoreInformation()
   File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
     return self.__r_call(*args, **kw)
   File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
     self.__hd, self.__ma)
   File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
     config = self.config)
   File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
     r.endheaders()
   File "C:\Python23\lib\httplib.py", line 712, in endheaders
     self._send_output()
   File "C:\Python23\lib\httplib.py", line 597, in _send_output
     self.send(msg)
   File "C:\Python23\lib\httplib.py", line 564, in send
     self.connect()
   File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
     self.sock.connect(self.host, self.port, self.io_attr)
   File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
     raise ex
GSITCPSocketException: a system call failed (Invalid argument)
10/04/04 17:48:56 508 SharedPresentation     sharedpresentation.py:545
ERROR Exception getting filenames from venue.
   File "SharedPresentation.py", line 538, in updateVenueFileList
     filenames = self.queryVenueFilesCallback("*.ppt")
   File "SharedPresentation.py", line 1525, in QueryVenueFiles
     filenames = dsc.QueryMatchingFiles(file_query)
AttributeError: 'NoneType' object has no attribute 'QueryMatchingFiles'
10/04/04 17:49:01 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:02 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:02 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:02 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:03 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:03 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:11 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:12 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:12 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:12 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:13 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:13 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:13 508 SharedPresentation     sharedpresentation.py:433
DEBUG SharedPresentation.LocalUploadCB:['C:\\Randy\\PSG\\AG\\AG_2004.ppt']
10/04/04 17:49:13 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:14 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:14 508 SharedPresentation     sharedpresentation.py:440
ERROR Can not upload file C:\Randy\PSG\AG\AG_2004.ppt to data store
   File "SharedPresentation.py", line 438, in LocalUploadCB
     self.localUploadCallback([file])
   File "SharedPresentation.py", line 1520, in LocalUpload
     dsc.Upload(filename)
AttributeError: 'NoneType' object has no attribute 'Upload'
10/04/04 17:49:14 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:15 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:15 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:17 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:18 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:18 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:18 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:19 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:19 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:22 508 SharedPresentation     sharedpresentation.py:967
DEBUG Method QuitCB called
10/04/04 17:49:22 3124 SharedPresentation     sharedpresentation.py:810
DEBUG Got Event: local quit None
10/04/04 17:49:22 3124 SharedPresentation     sharedpresentation.py:1216
DEBUG Method Quit called
10/04/04 17:49:22 508 DataStoreClient     datastoreclient.py:40
10/04/04 17:49:23 508 DataStoreClient     datastoreclient.py:45 ERROR
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
     raise ex
10/04/04 17:49:23 508 SharedPresentation     sharedpresentation.py:545
10/04/04 17:49:23 508 SharedPresentation     sharedpresentation.py:762
DEBUG Shutting down...
10/04/04 17:49:23 508 EventClient     eventclient.py:303 DEBUG Cancel
pending callbacks
10/04/04 17:49:23 2696 EventClient     eventclient.py:177 DEBUG Read
Callback called arg=None handle=_18d32602_p_globus_io_handle_t result=(-1,
22, 'an I/O operation was cancelled')  n=0
10/04/04 17:49:23 2696 EventClient     eventclient.py:180 DEBUG
readCallback gets failure in result: -1 22
10/04/04 17:49:23 508 EventClient     eventclient.py:309 DEBUG Free
10/04/04 17:49:23 508 EventClient     eventclient.py:315 DEBUG
EventClient.Stop: closing socket
10/04/04 17:49:23 508 EventClient     eventclient.py:323 DEBUG
EventClient.Stop: closing queue
