[AG-TECH] Can't store node configuration
Wesley Skoczen
wesley.skoczen at sheridanc.on.ca
Mon Oct 4 11:48:41 CDT 2004
Hi everybody,
I have AG 2.3 installed (audio and video on FC2, display on WinXP SP2, node service is running on WinXP).
I can't store node configuration. I was using workaround recommended on this list earlier, and created empty file in
C:\Documents and Settings\USER\Application Data\AccessGrid\Config\nodeConfig
but it doesn't work, is there any other solution? Could somebody send me a sample configuration file for 3 machines node, so I can use it as template.
Attached is relevant log output.
Thank You
Wesley
10/04/2004 12:26:17 PM -216478800 ServiceManager __init__.py:988 INFO AGServiceManager.GetServices
10/04/2004 12:26:17 PM -151059712 NodeManagementUIClasses __init__.py:988 ERROR Error storing node configuration defaultWindows
Traceback (most recent call last):
File \"/usr/lib/python2.3/site-packages/AccessGrid/NodeManagementUIClasses.py\", line 688, in StoreConfiguration
self.nodeServiceHandle.StoreConfiguration( configName )
File \"/usr/lib/python2.3/site-packages/AccessGrid/AGNodeService.py\", line 1159, in StoreConfiguration
self.proxy.StoreConfiguration(configName)
File \"/usr/lib/python2.3/site-packages/SOAPpy/Client.py\", line 453, in __call__
return self.__r_call(*args, **kw)
File \"/usr/lib/python2.3/site-packages/SOAPpy/Client.py\", line 475, in __r_call
self.__hd, self.__ma)
File \"/usr/lib/python2.3/site-packages/SOAPpy/Client.py\", line 389, in __call
raise p
faultType: <Fault SOAP-ENV:Server: Method Failed: NodeService:StoreConfiguration>
