[AG-TECH] Can't store node configuration
Thomas D. Uram
turam at mcs.anl.gov
Mon Oct 4 12:06:47 CDT 2004
Hi Wesley:
I'm interested in how the software failed. I expect that the output you
included was from VenueClient.log; there should be more info about the
failure either in this file, or in NodeService.log, depending on how you
were running the software. Could you send more of the log file, and
possibly the NodeService.log file so I can look into the problem?
The workaround was for the 2.2 release only, and shouldn't apply to the
2.3 software.
Tom
Wesley Skoczen wrote:
> Hi everybody,
> I have AG 2.3 installed (audio and video on FC2, display on WinXP SP2,
> node service is running on WinXP).
> I can't store node configuration. I was using workaround recommended on
> this list earlier, and created empty file in C:\Documents and
> Settings\USER\Application Data\AccessGrid\Config\nodeConfig
> but it doesn't work, is there any other solution? Could somebody send me
> a sample configuration file for 3 machines node, so I can use it as
> template.
> Attached is relevant log output.
> Thank You
> Wesley
> 10/04/2004 12:26:17 PM -216478800 ServiceManager __init__.py:988
> INFO AGServiceManager.GetServices
> 10/04/2004 12:26:17 PM -151059712 NodeManagementUIClasses
> __init__.py:988 ERROR Error storing node configuration defaultWindows
> Traceback (most recent call last):
> File
> \"/usr/lib/python2.3/site-packages/AccessGrid/NodeManagementUIClasses.py\",
> line 688, in StoreConfiguration
> self.nodeServiceHandle.StoreConfiguration( configName )
> File \"/usr/lib/python2.3/site-packages/AccessGrid/AGNodeService.py\",
> line 1159, in StoreConfiguration
> self.proxy.StoreConfiguration(configName)
> File \"/usr/lib/python2.3/site-packages/SOAPpy/Client.py\", line 453,
> in __call__
> return self.__r_call(*args, **kw)
> File \"/usr/lib/python2.3/site-packages/SOAPpy/Client.py\", line 475,
> in __r_call
> self.__hd, self.__ma)
> File \"/usr/lib/python2.3/site-packages/SOAPpy/Client.py\", line 389,
> in __call
> raise p
> faultType: <Fault SOAP-ENV:Server: Method Failed:
> NodeService:StoreConfiguration>
