[AG-TECH] Proxy initialization error
    Jon Johansson
    jon.johansson at ualberta.ca
    Tue Nov 23 10:45:31 CST 2004
Hi Todd,
I saw the same error last night working on an AG node at home.
For some reason the AGServiceManager didn't start.
(Mine is an old install of 2.1.2 but the error looks pretty
much the same)
Start the service manager by hand and then start the venue client
and things should work.
Jon.
Jon I Johansson             *  Research Computing Support
jon.johansson at ualberta.ca   *  Computing and Network Services
Tel.: (780) 492-9304        *  University of Alberta
Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Todd Reed
> Sent: Tuesday, November 23, 2004 8:21 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Proxy initialization error
> This is a new install of AGTk 2.3  When try to run the
> Service Manager, I
> get the following error on my display machine (the other two
> machines work
> fine):   [Any suggestions?]
> No globus proxy found, creating..
> Creating globus proxy for /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=astate.edu/C
> N=Todd Reed
> Passphrase:
> Lifetime in hours [12]:
> Keysize [1024]:
> Your identity: /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=astate.edu/CN=Todd
> Reed
> user_key loaded
> user_proxy cert_chain
> verify failed
> Proxy initialization error:  ('cannot find CA certificate for local
> credential',
> 'subject=/O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=astate.edu/CN=Todd Reed\n
>      issuer =/O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
> Developers CA
> Starting Service Manager URL:
> https://147.97.46.119:11000/ServiceManager
> _________________________________________________________________
> Don't just search. Find. Check out the new MSN Search!
> http://search.msn.click-url.com/go/onm00200636ave/direct/01/
