[AG-TECH] Proxy initialization error
    Todd Reed
    ex279 at hotmail.com
    Tue Nov 23 12:21:10 CST 2004
For some reason, that didn't work for me.  I doscovered there is a
AccessGrid folder in the Documents and Settings of the Windows users.  It's
hidden!  I had to uninstall the toolkit, delete the folder, reinstall the
toolkit, then reimport my certificate.  I think it was trying to read an old
or another certificate that was previously used.  The certificates appear to
be stored in this directory.
Todd
>From: "Jon Johansson" <jon.johansson at ualberta.ca>
>To: "'Todd Reed'" <ex279 at hotmail.com>, <ag-tech at mcs.anl.gov>
>Subject: RE: [AG-TECH] Proxy initialization error
>Date: Tue, 23 Nov 2004 09:45:31 -0700
>Hi Todd,
>I saw the same error last night working on an AG node at home.
>For some reason the AGServiceManager didn't start.
>(Mine is an old install of 2.1.2 but the error looks pretty
>much the same)
>Start the service manager by hand and then start the venue client
>and things should work.
>Jon.
>Jon I Johansson             *  Research Computing Support
>jon.johansson at ualberta.ca   *  Computing and Network Services
>Tel.: (780) 492-9304        *  University of Alberta
>Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Todd Reed
> > Sent: Tuesday, November 23, 2004 8:21 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] Proxy initialization error
> > This is a new install of AGTk 2.3  When try to run the
> > Service Manager, I
> > get the following error on my display machine (the other two
> > machines work
> > fine):   [Any suggestions?]
> > No globus proxy found, creating..
> > Creating globus proxy for /O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=astate.edu/C
> > N=Todd Reed
> > Passphrase:
> > Lifetime in hours [12]:
> > Keysize [1024]:
> > Your identity: /O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=astate.edu/CN=Todd
> > Reed
> > user_key loaded
> > user_proxy cert_chain
> > verify failed
> > Proxy initialization error:  ('cannot find CA certificate for local
> > credential',
> > 'subject=/O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=astate.edu/CN=Todd Reed\n
> >      issuer =/O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
> > Developers CA
> > Starting Service Manager URL:
> > https://147.97.46.119:11000/ServiceManager
> > _________________________________________________________________
> > Don't just search. Find. Check out the new MSN Search!
> > http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Is your PC infected? Get a FREE online computer virus scan from McAfee®
Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
