[AG-TECH] New Fedora AGTk 2.3 RPMs released
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Mon Nov 15 15:58:21 CST 2004
On Mon, 2004-11-15 at 09:15 -0800, Todd Zimmerman wrote:
> Hi Doug,
> I just updated my Fedora install and now the VenueClient fails to start.
>    Email if you want the logs, here's the traceback:
> Any Suggestions??
> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
> line 25, in ?
>      from pyGlobus import security
> ImportError: No module named pyGlobus
If you issue the following:
  rpm -ql AccessGrid-2.3-5 | grep pyGlobus
and it doesn't spit out:
  /usr/lib/python2.3/site-packages/pyGlobus
  /usr/lib/python2.3/site-packages/pyGlobus/__init__.py
you may also want to check if those files actually exist on the
filesystem.
if they don't you may have downloaded the first
AccessGrid-2.3-5.i386.rpm for FC2 that I put on my site that was corrupt
(it wasn't up there for too long).
Re-downloadind and re-installing AccessGrid-2.3-5.i386.rpm should fix
it, e.g.:
rpm -e AccessGrid-2.3
wget \
http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/RPMS/i386/AccessGrid-2.3-5.i386.rpm
rpm -ivh AccessGrid-2.3-5.i386.rpm
Sorry for any inconvenience.
Cheers,
Doug
