[AG-TECH] New Fedora AGTk 2.3 RPMs released
Todd Zimmerman
toddz at sfu.ca
Mon Nov 15 11:15:18 CST 2004
Hi Doug,
I just updated my Fedora install and now the VenueClient fails to start.
Email if you want the logs, here's the traceback:
Any Suggestions??
File "/usr/bin/VenueClient.py", line 28, in ?
from AccessGrid.Toolkit import WXGUIApplication
File "/usr/lib/python2.3/site-packages/AccessGrid/Toolkit.py", line
22, in ?
from AccessGrid.Security import CertificateManager
File
"/usr/lib/python2.3/site-packages/AccessGrid/Security/CertificateManager.py",
line 49, in ?
from AccessGrid import Utilities
File "/usr/lib/python2.3/site-packages/AccessGrid/Utilities.py", line
32, in ? from AccessGrid import Platform
File
"/usr/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py", line
55, in ?
from AccessGrid.Platform.unix import Config as Config
File
"/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
line 25, in ?
from pyGlobus import security
ImportError: No module named pyGlobus
[tz at floyd tz]$ VenueClient.py --personalNode
Traceback (most recent call last):
22, in ?
File
line 49, in ?
File
55, in ?
File
line 25, in ?
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Douglas Kosovic wrote:
> Hi,
> New Fedora AGTk 2.3 RPMs have been released, see:
> http://www.itee.uq.edu.au/~agn/ag_fedora/
> Note: yum and up2date URLs in /etc/yum.conf and
> /etc/sysconfig/rhn/sources have changed. The changes were necessary to
> make provisions for x86_64 AGTk RPMs.
> Fedora Core 1 AGTk 2.3 RPMs should now cleanly install on Red Hat 9 and
> Enterprise 3. Installation instructions can be found on the above web page.
> The problem with the rat GUI not coming up in some situations has been
> rectified.
> Vic now works with the Kensington 67014 webcams and other RGB24 capture
> devices. Vic was built with the patch from:
> http://ihpc.jcu.edu.au/~jc118215/index.php/Main/AccessGrid
> SharedPresentation now works correctly in full-screen slide show mode.
> Doug
