[AG-TECH] debian sid build of AG2.2 tarball
    Thomas D. Uram
    turam at mcs.anl.gov
    Fri May 21 17:47:05 CDT 2004
You can look in the VenueClient.log file for an indication of what went
wrong. You might be able to determine the source of the text failure by
looking in the log. Since the client locked up trying to enter another
venue, that problem may not be reflected in the log.
Of course, if the log isn't all that helpful to you, you can send it
along for me (and others) to look at. I'd be happy to answer any
questions that will help you get the software working properly on Debian.
Tom
Gavin W. Burris aka 86 wrote:
>That fixed it.
>I can even fire up:
>$ VenueClient.py --personalNode
>That lets me import my certificate and into the lobby.  But then I
>can't see text I type into the chat window and it locks when I try and
>navigate to another venue.
>Any tips for me on debugging?
>Thomas D. Uram wrote (on Fri, 21 May 2004 at 15:45):
>>Hi Gavin:
>>I suspect you're using an older version of gpt. We've been using
>>gpt3.0.1, which is the version included in the gt3.0.2 source installer
>>http://www-unix.globus.org/ftppub/gt3/3.0/3.0.2/gt3.0.2-source-installer.tar.gz
>>). You can also get gpt from http://www.gridpackagingtools.org .
>>I need to update the linux build howto document to reflect the details
>>of the new build process, to facilitate packaging for other distros I'll
>>let you know when that's done. Meanwhile, let me know if you have any
>>questions.
>>Tom
>>>So I have managed to build the Globus toolkit that is included in the
>>>AG2.2 Beta tarball as per:
>>>http://www.globus.org/gt2/install/index.html
>>>But how do I build pyGlobus against it?  What modules?  The build
>>>with "python2.3 setup.py --flavor=gcc32dbgpthr build" bombs out on:
>>>Checking the io module
>>>Traceback (most recent call last):
>>> File "setup.py", line 878, in ?
>>>   pyModList, eModList, swigList = build_module_lists()
>>> File "setup.py", line 230, in build_module_lists
>>>   check_io(pyModList, eModList, swigList)
>>> File "setup.py", line 542, in check_io
>>>   major, minor = check_version(dep)
>>>TypeError: unpack non-sequence
>>>Cheers,
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040521/ab86350c/attachment.htm>
