[AG-TECH] debian sid build of AG2.2 tarball
    Gavin W. Burris aka 86
    ga5in at psu.edu
    Fri May 21 17:40:31 CDT 2004
That fixed it.
I can even fire up:
$ VenueClient.py --personalNode
That lets me import my certificate and into the lobby.  But then I
can't see text I type into the chat window and it locks when I try and
navigate to another venue.
Any tips for me on debugging?
Thomas D. Uram wrote (on Fri, 21 May 2004 at 15:45):
> Hi Gavin:
> I suspect you're using an older version of gpt. We've been using
> gpt3.0.1, which is the version included in the gt3.0.2 source installer
> http://www-unix.globus.org/ftppub/gt3/3.0/3.0.2/gt3.0.2-source-installer.tar.gz
> ). You can also get gpt from http://www.gridpackagingtools.org .
> I need to update the linux build howto document to reflect the details
> of the new build process, to facilitate packaging for other distros I'll
> let you know when that's done. Meanwhile, let me know if you have any
> questions.
> Tom
> Gavin W. Burris aka 86 wrote:
> >So I have managed to build the Globus toolkit that is included in the
> >AG2.2 Beta tarball as per:
> >http://www.globus.org/gt2/install/index.html
> >But how do I build pyGlobus against it?  What modules?  The build
> >with "python2.3 setup.py --flavor=gcc32dbgpthr build" bombs out on:
> >Checking the io module
> >Traceback (most recent call last):
> >  File "setup.py", line 878, in ?
> >    pyModList, eModList, swigList = build_module_lists()
> >  File "setup.py", line 230, in build_module_lists
> >    check_io(pyModList, eModList, swigList)
> >  File "setup.py", line 542, in check_io
> >    major, minor = check_version(dep)
> >TypeError: unpack non-sequence
> >Cheers,
Senior Systems Programmer
Penn State Visualization Group
http://viz.aset.psu.edu/ga5in
