[AG-TECH] debian sid build of AG2.2 tarball
    Thomas D. Uram
    turam at mcs.anl.gov
    Fri May 21 15:45:52 CDT 2004
Hi Gavin:
I suspect you're using an older version of gpt. We've been using
gpt3.0.1, which is the version included in the gt3.0.2 source installer
http://www-unix.globus.org/ftppub/gt3/3.0/3.0.2/gt3.0.2-source-installer.tar.gz
). You can also get gpt from http://www.gridpackagingtools.org .
I need to update the linux build howto document to reflect the details
of the new build process, to facilitate packaging for other distros I'll
let you know when that's done. Meanwhile, let me know if you have any
questions.
Tom
Gavin W. Burris aka 86 wrote:
>So I have managed to build the Globus toolkit that is included in the
>AG2.2 Beta tarball as per:
>http://www.globus.org/gt2/install/index.html
>But how do I build pyGlobus against it?  What modules?  The build
>with "python2.3 setup.py --flavor=gcc32dbgpthr build" bombs out on:
>Checking the io module
>Traceback (most recent call last):
>  File "setup.py", line 878, in ?
>    pyModList, eModList, swigList = build_module_lists()
>  File "setup.py", line 230, in build_module_lists
>    check_io(pyModList, eModList, swigList)
>  File "setup.py", line 542, in check_io
>    major, minor = check_version(dep)
>TypeError: unpack non-sequence
>Cheers,
