[AG-TECH] debian sid build of AG2.2 tarball
    Gavin W. Burris aka 86
    ga5in at psu.edu
    Fri May 21 15:34:50 CDT 2004
So I have managed to build the Globus toolkit that is included in the
AG2.2 Beta tarball as per:
http://www.globus.org/gt2/install/index.html
But how do I build pyGlobus against it?  What modules?  The build
with "python2.3 setup.py --flavor=gcc32dbgpthr build" bombs out on:
Checking the io module
Traceback (most recent call last):
  File "setup.py", line 878, in ?
    pyModList, eModList, swigList = build_module_lists()
  File "setup.py", line 230, in build_module_lists
    check_io(pyModList, eModList, swigList)
  File "setup.py", line 542, in check_io
    major, minor = check_version(dep)
TypeError: unpack non-sequence
Cheers,
Senior Systems Programmer
Penn State Visualization Group
http://viz.aset.psu.edu/ga5in
