Trusted certs - was: RE: [AG-TECH] AG2.2 and above on Win2K?
    Ivan R. Judson
    judson at mcs.anl.gov
    Wed May 19 15:58:47 CDT 2004
Supreeya,
Have you seen this in the 2.2 software? I think that's what Jon is trying --
but if you've seen it in 2.2 please let us know so we can fix it before the
final release.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Supreeya Miller
> Sent: Wednesday, May 19, 2004 3:37 PM
> To: ACCESS community; Jon Johansson
> Subject: RE: Trusted certs - was: RE: [AG-TECH] AG2.2 and
> above on Win2K?
> Jon,
> Your certificate is probably ok.  It is a bug of this version
> that the certificate was imported, but somehow the trusted
> certificate did not get done properly.
> Here what I did (by the help from Robert Olson):
> 	1. Run the Venue Client,
> 	2. Click on Preferences > Manage Certificates > View
> Identity Certificate,
> 		(Since I had problem, I requested many certs.)
> 	   Keep the certificate that I knew for sure what the
> password was and deleted the rest (I could have exported them
> for other uses.)
> 	3. Click on Preferences again, choose Manage
> Certificates > View Trusted CA certificates.
> 	   At this point I think I clicked on Import.  Then I
> got the trusted certificates imported.
> Then it logged me in immediately without asking for a passphrase.
> After that I had no problem using the AG2.
> Supreeya Miller
> Visualization Researcher, System Administrator, and Access
> Grid Coordinator Center of Higher Learning Building 1103
> Stennis Space Center, MS  39529 228-688-2190 Internal Mail
> Box: 10002 Supreeya.Miller at usm.edu
> From: Jon Johansson [mailto:jon.johansson at ualberta.ca]
> Sent: Wednesday, May 19, 2004 2:18 PM
> To: 'Supreeya Miller'
> Subject: Trusted certs - was: RE: [AG-TECH] AG2.2 and above on Win2K?
> I'm getting a password error on a WinXP machine with the same
> user certs that I use on other machines.
> I've checked that the certs that I imported are not corrupted
> and my configuration seems ok.
> How do I check the trusted certs and where do I get them if
> they don't come with the installation?
> Thanks,
> Jon.
> Jon I Johansson             *  Research Computing Support
> jon.johansson at ualberta.ca   *  Computing and Network Services
> Tel.: (780) 492-9304        *  University of Alberta
> Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
> > Sent: Wednesday, May 19, 2004 1:58 PM
> > To: Randy Groves; ag-tech at mcs.anl.gov
> > Subject: RE: [AG-TECH] AG2.2 and above on Win2K?
> > Randy,
> > At CHL, we are running a room node with 4 machines.  The Display
> > machine is running Windows 2000.
> > The 2.1.2 installation was easy and smooth.  However, I had an
> > installation problem on a PIG XP that it did not have a trusted
> > certificate and reported as having a bad password entered instead.
> > Supreeya Miller
> > Visualization Researcher, System Administrator, and Access Grid
> > Coordinator Center of Higher Learning Building 1103 Stennis Space
> > Center, MS  39529 228-688-2190 Internal Mail Box: 10002
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Randy Groves
> > Sent: Wednesday, May 19, 2004 11:44 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] AG2.2 and above on Win2K?
> > First of all, are people successfully running 2.1.2 on Win2K?
> >  I've had
> > some problems recently getting it running on this platform
> - at this
> > juncture, I don't remember the details.  But this issue looks like
> > it's going to raise it's head again, so I'll probably have
> to revisit
> > it.
> > But that brings up a larger question, which is significant in our
> > situation, where XP is just now starting to be installed in
> selected
> > areas.  Is Win2K a dead platform as far as the AG is concerned?
> > -randy
