Trusted certs - was: RE: [AG-TECH] AG2.2 and above on Win2K?
    Supreeya Miller
    Supreeya.Miller at usm.edu
    Wed May 19 15:37:17 CDT 2004
Jon,
Your certificate is probably ok.  It is a bug of this version that the
certificate was imported, but somehow the trusted certificate did not get
done properly.
Here what I did (by the help from Robert Olson):
	1. Run the Venue Client,
	2. Click on Preferences > Manage Certificates > View Identity Certificate,
		(Since I had problem, I requested many certs.)
	   Keep the certificate that I knew for sure what the password was and
deleted the rest (I could have exported them for other uses.)
	3. Click on Preferences again, choose Manage Certificates > View Trusted CA
certificates.
	   At this point I think I clicked on Import.  Then I got the trusted
certificates imported.
Then it logged me in immediately without asking for a passphrase.
After that I had no problem using the AG2.
Supreeya Miller
Visualization Researcher, System Administrator, and Access Grid Coordinator
Center of Higher Learning
Building 1103
Stennis Space Center, MS  39529
228-688-2190
Internal Mail Box: 10002
-----Original Message-----
From: Jon Johansson [mailto:jon.johansson at ualberta.ca]
Sent: Wednesday, May 19, 2004 2:18 PM
To: 'Supreeya Miller'
Subject: Trusted certs - was: RE: [AG-TECH] AG2.2 and above on Win2K?
I'm getting a password error on a WinXP machine with
the same user certs that I use on other machines.
I've checked that the certs that I imported are not
corrupted and my configuration seems ok.
How do I check the trusted certs and where do I get
them if they don't come with the installation?
Jon.
Jon I Johansson             *  Research Computing Support
jon.johansson at ualberta.ca   *  Computing and Network Services
Tel.: (780) 492-9304        *  University of Alberta
Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Supreeya Miller
> Sent: Wednesday, May 19, 2004 1:58 PM
> To: Randy Groves; ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] AG2.2 and above on Win2K?
> Randy,
> At CHL, we are running a room node with 4 machines.  The
> Display machine is
> running Windows 2000.
> The 2.1.2 installation was easy and smooth.  However, I had
> an installation
> problem on a PIG XP that it did not have a trusted
> certificate and reported
> as having a bad password entered instead.
> Supreeya Miller
> Grid Coordinator
> Building 1103
> 228-688-2190
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Randy Groves
> Sent: Wednesday, May 19, 2004 11:44 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] AG2.2 and above on Win2K?
> First of all, are people successfully running 2.1.2 on Win2K?
>  I've had
> some problems recently getting it running on this platform - at this
> juncture, I don't remember the details.  But this issue looks
> like it's
> going to raise it's head again, so I'll probably have to revisit it.
> But that brings up a larger question, which is significant in our
> situation, where XP is just now starting to be installed in selected
> areas.  Is Win2K a dead platform as far as the AG is concerned?
> -randy
