[AG-TECH] Granularity of saved information for sessions
    Brian Corrie
    bcorrie at sfu.ca
    Tue May 18 13:43:10 CDT 2004
Hi Tom,
Do you have a plan and roadmap for application/service control for AG?
We have a student (at least our NRC colleagues in Ottawa do) working on
this and it would be good if we could find out what your roadmap is.
This way we could feed back our needs (as could others) into your design...
Cheers,
Brian
Thomas D. Uram wrote:
> Randy:
> In the 2.2 release, the audio service includes options for the default
> values of talk (mute), input gain, and output gain.  These are saved in
> the node config, so will be used whenever you load a node config.  You
> should note that these options are only applied when rat starts, and do
> not adjust rat interactively; interactive control of rat will show up in
> a release after 2.2.
> Tom
> Randy Groves wrote:
>> I haven't seen much discussion of this, but I'm wondering how much
>> granularity there is going to be in the saved setup information.  For
>> instance, I may know that for a particular set of participants, I will
>> want to start with my RAT turned down fairly low, and only one camera
>> running, but muted.  I know that I can control whether the camera is
>> there or not with a node config, but I think that is the level of the
>> granularity, if I'm not mistaken.
>> -randy
