[AG-TECH] Granularity of saved information for sessions
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue May 18 15:04:53 CDT 2004
Hi Brian:
The plan at this point relates to coordinating control of the services
in a node, which implies a richer description of service capabilities,
service advertisement and discovery, and interactive control.  Some
applications look like they might blend this sort of functionality with
the shared app support, so we'll have to consider that also.
We'll be formalizing at least some of these ideas for the next
development cycle, so it would be ideal to be able to consider your
requirements beforehand.  Please do send them along, or file
enhancements to current functionality in Bugzilla.
Tom
Brian Corrie wrote:
> Hi Tom,
> Do you have a plan and roadmap for application/service control for AG?
> We have a student (at least our NRC colleagues in Ottawa do) working
> on this and it would be good if we could find out what your roadmap
> is. This way we could feed back our needs (as could others) into your
> design...
> Cheers,
> Brian
> Thomas D. Uram wrote:
>> Randy:
>> In the 2.2 release, the audio service includes options for the
>> default values of talk (mute), input gain, and output gain.  These
>> are saved in the node config, so will be used whenever you load a
>> node config.  You should note that these options are only applied
>> when rat starts, and do not adjust rat interactively; interactive
>> control of rat will show up in a release after 2.2.
>> Tom
>> Randy Groves wrote:
>>> I haven't seen much discussion of this, but I'm wondering how much
>>> granularity there is going to be in the saved setup information.
>>> For instance, I may know that for a particular set of participants,
>>> I will want to start with my RAT turned down fairly low, and only
>>> one camera running, but muted.  I know that I can control whether
>>> the camera is there or not with a node config, but I think that is
>>> the level of the granularity, if I'm not mistaken.
>>> -randy
