[AG-TECH] Granularity of saved information for sessions
Thomas D. Uram
turam at mcs.anl.gov
Tue May 18 12:34:22 CDT 2004
Randy:
In the 2.2 release, the audio service includes options for the default
values of talk (mute), input gain, and output gain. These are saved in
the node config, so will be used whenever you load a node config. You
should note that these options are only applied when rat starts, and do
not adjust rat interactively; interactive control of rat will show up in
a release after 2.2.
Tom
Randy Groves wrote:
> I haven't seen much discussion of this, but I'm wondering how much
> granularity there is going to be in the saved setup information. For
> instance, I may know that for a particular set of participants, I will
> want to start with my RAT turned down fairly low, and only one camera
> running, but muted. I know that I can control whether the camera is
> there or not with a node config, but I think that is the level of the
> granularity, if I'm not mistaken.
> -randy
