[AG-TECH] Venue Server firewall iissues?
    NamGon Kim
    ngkim at netmedia.kjist.ac.kr
    Mon May 10 09:12:45 CDT 2004
Hi, Natalia.
I think maybe the port number of ANL is different from your own venue server.
Cause I think if you can connect to ANL server outside the firewall, then we can think that the firewall can make a connection with outside with some port number.
So if the firewall can not make connection with your own venue server,
I suggest you to check your venue server's port number.
And one more thing about venue client is it makes a event client which gets information from venue server. Event information, such as users come in or going out.
So venue client has incoming connection.
I am working on NAT and Firewall problems on AG.
So I would like to get problem information about this matter.
Namgon
Namgon Kim
Netmedia Lab, GIST, KOREA
http://netmedia.kjist.ac.kr
-----Original Message-----
From: Natalia Costas Lago [mailto:natalia at cesga.es]
Sent: Monday, May 10, 2004 10:48 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Venue Server ¢¯firewall iissues?
Hi all,
We've found a new (let's hope) small problem related to our Venue Server
configuration. We have a LAN set up outside the firewall where the Venue
Server is running. I can connect to it using a Venue Client running in the
same LAN. The problem is that I can't connect to it with a Venue Client
located behind the firewall (although it can connect to ANL venue server).
Any idea why our Venue client can connect to ANL but it cant to our own
Venue Server?
Theorically, the Venue Client has only outgoing connections, is this
correct? (i'm not working with shared data so far, that will be the next
step).
Kind regards and thanx,
Natalia.
Natalia Costas Lago
mailto: natalia at cesga.es
Centro de Supercomputacion de Galicia (CESGA)
Avenida de Vigo, s/n Campus Sur
15705 Santiago de Compostela - SPAIN
Tel: +34  981 56 98 10
Fax: +34  981 59 46 16
http://www.cesga.es/
