[AG-TECH] Building Alpha 2.2 (VIC) source under Windows XP and VS .NET
Sabihuddin, Siraj
Siraj.Sabihuddin at nrc-cnrc.gc.ca
Mon May 10 07:11:04 CDT 2004
I am trying to compile the VIC source files for the the Alpha 2.2 release of
the Access Grid Toolkit - I was hoping that someone could help me out.
Using the Visual Studio .Net 2003 (VC7) projects, I get syntax errors on
compilation of the tcl2c generated C files...(note: TCL/TK 8.0 binaries are
already installed on my system)
For example, in the TCLLIB and TKLIB projects the following errors are
generated on compilation:
......\ag-media\tcl-8.0\win\lib_word.c(3): error C2059: syntax error : '}'
......\ag-media\tcl-8.0\win\lib_safe.c(3): error C2059: syntax error : '}'
......\ag-media\tcl-8.0\win\lib_parray.c(3): error C2059: syntax error :
......\ag-media\tcl-8.0\win\lib_optparse.c(3): error C2059: syntax error :
......\ag-media\tcl-8.0\win\lib_ldAout.c(3): error C2059: syntax error :
......\ag-media\tcl-8.0\win\lib_init.c(3): error C2059: syntax error : '}'
......\ag-media\tcl-8.0\win\lib_http.c(3): error C2059: syntax error : '}'
......\ag-media\tcl-8.0\win\lib_history.c(3): error C2059: syntax error :
......\ag-media\tk-8.0\win\lib_xmfbox.c(3): error C2059: syntax error :
......\ag-media\tk-8.0\win\lib_tkfbox.c(3): error C2059: syntax error :
......\ag-media\tk-8.0\win\lib_tk.c(3): error C2059: syntax error : '}'
......\ag-media\tk-8.0\win\lib_text.c(3): error C2059: syntax error : '}'
If I modify any of these files and enter a character place holder in between
the curly braces and recompile, the files compile fine; for example:
ORIGINAL LIB_HISTORY.C (gives syntax errors)
char lib_history[] = {};
MODIFIED LIB_HISTORY.C (compiles fine)
char lib_history[] = {'\0'};
Because the TCL/TK 8.0 binaries are already installed on my system, I have
tried to bypass the compilation of TCLLIB & TKLIB; however this results in a
"[mkcube] usage error at the custom build step" of the compilation process.
(Note: I have managed to get a previous version of VIC to compile (libraries
and all) with VC6 -> VC7 gives the same problems as above with the previous
version)
How would I go about fixing these errors and compiling the VIC code? Any
help you can give, would be appreciated. Thanks!
Siraj
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040510/f4229ed6/attachment.htm>
