[AG-TECH] access grid newbie help
    Steve Gallo
    smgallo at ccr.buffalo.edu
    Mon May  3 10:14:35 CDT 2004
Have you tried to telnet to port 12000 on the linux box?  Did you
check your firewall settings?
Steve
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Aaron Lafferty
> Sent: Monday, May 03, 2004 11:01 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] access grid newbie help
> Hi again all!
> Well I have the time synced up between the boxes to within 1 second of
> each other.  Sadly the linux boxes absolutely do not want to use
> ntp-1.accessgrid.org but the windows box will.  So they sync to the US
> Naval Observatory time standard and that works fine.
> However, the node manager wizard still claims it cannot connect to the
> linux boxes when I have run AGServiceManager.py running.
> I still think that I am obviously missing something in my setup but I
> don't know what.  Is there a step by step set of documentation that
> someone can point me at which tells me what needs done for each box in
> the node?  I've been looking around but haven't run into such a document
> myself.
> Open to ideas...
> Thanks,
> Aaron
