[AG-TECH] access grid newbie help
    Aaron Lafferty
    lafferty at oar.net
    Mon May  3 10:44:55 CDT 2004
I can telnet to port 12k on the linux box and I turned off all the
iptables and ipchains.  There is no firewall between the two devices,
they are on the same subnet...
thanks,
-aaron
On Mon, 2004-05-03 at 11:14, Steve Gallo wrote:
> Have you tried to telnet to port 12000 on the linux box?  Did you
> check your firewall settings?
> Steve
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Aaron Lafferty
> > Sent: Monday, May 03, 2004 11:01 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] access grid newbie help
> > Hi again all!
> > Well I have the time synced up between the boxes to within 1 second of
> > each other.  Sadly the linux boxes absolutely do not want to use
> > ntp-1.accessgrid.org but the windows box will.  So they sync to the US
> > Naval Observatory time standard and that works fine.
> > However, the node manager wizard still claims it cannot connect to the
> > linux boxes when I have run AGServiceManager.py running.
> > I still think that I am obviously missing something in my setup but I
> > don't know what.  Is there a step by step set of documentation that
> > someone can point me at which tells me what needs done for each box in
> > the node?  I've been looking around but haven't run into such a document
> > myself.
> > Open to ideas...
> > Thanks,
> > Aaron
