[AG-TECH] Re: IPv6 support in VP
Rhys Hawkins
rhys.hawkins at anu.edu.au
Sun Mar 7 21:15:13 CST 2004
Sorry to disappoint people, but VP/librtp doesn't support IPv6 as
yet. I've stubbed in the ipv6 code but there is no implementation.
I designed the lower levels of librtp so that VP (for example) doesn't
care where the RTP packets come from, be it IPv4, IPv6, file or
something else I haven't thought of yet.
For VP to support IPv6, all that has to be done is the implementation
of the stubs, and perhaps some extra parsing to cope with the different
presentation format. If people are keen for this and I can get access
to a IPv6 machine/network for testing then this could be available
in the next point release of VP.
Cheers,
Rhys
On Mon, 2004-03-08 at 12:36, Markus Buchhorn wrote:
> I didn't know we had some ipv6 support already??? Good stuff!! :-)
> >From: "Piers O'Hanlon" <P.OHanlon at cs.ucl.ac.uk>
> >To: judson <judson at mcs.anl.gov>
> >cc: "'Tim Chown'" <tjc at ecs.soton.ac.uk>, natalia <natalia at cesga.es>,
> > ag-tech <ag-tech at mcs.anl.gov>,
> > "'Piers O'Hanlon'" <P.OHanlon at cs.ucl.ac.uk>,
> > "'David G Mills'" <dgm at ecs.soton.ac.uk>,
> > "'Peter Kirstein'" <P.Kirstein at cs.ucl.ac.uk>,
> > "'Brian Carpenter'" <brc at zurich.ibm.com>, P.OHanlon at cs.ucl.ac.uk
> >Subject: Re: [AG-TECH] AG IPv6 support
> >Date: Fri, 05 Mar 2004 17:28:32 +0000
> >Hi Ivan,
> >I noted the announcement of VP with interest - looks good - and appears that
> >there is some IPv6 code in librtp already - I haven't tested it fully yet. I
> >wasn't quite clear how to start it if it wasn't part of an AG session.
> >http://if.anu.edu.au/SW/VP.html
> >BTW any news on AG updates?
> >> > deployments. We both have IPv6 multicast deployed in a
> >> > production quality environment on 6NET (www.6net.org); both
> >> > PIM-SM and SSM IPv6 applications.
> >> > We have had ~30 partner vic/rat IPv6 PIM-SM sessions. We
> >> > have used FLUTE
> >> > and DVTS for IPv6 SSM.
> >> This is what we are interested in understanding and enabling, can you point
> >> me at more details?
> >The MAD flute application is available from:
> >http://www.atm.tut.fi/mad/
> >The high quality DVTS app is available from:
> >http://www.sfc.wide.ad.jp/DVTS/
> >SSM capable version:
> >http://www-sop.inria.fr/planete/Hitoshi.Asaeda/dvts/
> >> We have various documents of this flavor on the web (and in cvs):
> >> http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/index.html
> >> And http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/doc/
> >Will take a closer look.
> >> We're more than happy to answer questions as well.
> >> > We should definitely discuss this in more detail once that
> >> > analysis is done, as we could be of mutual help :)
> >> Let's plan on it. Are you all coming to the retreat? It'd be a great place
> >> to sit down and map out a solution.
> >Which retreat? We are headed to GGF10 next week in Berlin - it would be good
> >to meet with you (and/or some of your colleagues) if you're there.
> >Cheers,
> >Piers.
